Tick from front sprocket / chain? *video*
This is a discussion on Tick from front sprocket / chain? *video* within the General ZR-7 forums, part of the Kawasaki ZR-7 category; I've got something going on that I'm not sure if it's normal, I replaced the chain and sprockets when I got the bike 2 years ...
Results 1 to 9 of 9
    Rising Star 99GrandTouring's Avatar
    Mar 2003
    West Virginia
    201
    14 times
    I've got something going on that I'm not sure if it's normal, I replaced the chain and sprockets when I got the bike 2 years ago, it's done this ever since, the only way to get partially rid of it is if I run the chain tight which I don't like doing.
    Alignment has been checked over and over, it does it with my 17th and 16th sprockets, you can hear it very noticeable when pulling out, so what gives?
    Any ideas?
    https://youtu.be/oFu0ulWQ5sg
    2001 Kawasaki Zr7S
    Newbie TadyZ's Avatar
    Oct 2018
    9
    I think that's pretty normal, but i'm not an expert. Mine does that too and the chain is old.
    Are the new chain and sprockets made de REGINA? I ask because they are gold and I've just bought them and plan to replace for the new season.
    Oct 2018
    9
    Mar 2004
    Delaware
    1,059
    42 times
    Chain way too loose? Broken or missing rub block? Defective or cheap-o chain? Chain noise while spinning by hand is normal, but it shouldn't be so loud you can hear it while riding, IMHO.
    2015 Versys 650 ABS
    (Former owner 2003 ZR-7S)
    Mods/Farkles: Nat'l Cycle V-Stream windscreen, Givi hand guards, BMW grips, Omni-Cruise throttle lock, Motowerk mirror extenders, Denali Mini Soundbomb horn, SW-Motech luggage rack and side racks, Givi E-22 side cases, RKA 13L tank bag, RKA 36L rack bag, Motorwerk side stand foot, Motowerk highway peg set-up, SW-Motech wide foot pegs, SW-Motech GPS shelf, Hyper-Lites, seat riser mod, decalectomy
    Mar 2003
    West Virginia
    201
    14 times
    Chain was new did jt sprocket..
    So I decided to switch back to my 16th and I noticed something i missed before, look at the wear pattern on the back side of these sprockets..
    Front side looks like no contact?
    See polished spot on inside outer edges?
    2001 Kawasaki Zr7S
    Newbie M1shooter's Avatar
    Dec 2018
    Plant City, Florida
    10
    Correct width chain for the sprocket? Looks narrow.
    Mar 2003
    West Virginia
    201
    14 times
    Well back to the 16th, played around with alignment.
    I think chain got out of adjustment, justvtest rode noise is gone, we'll see if comes back.
    2001 Kawasaki Zr7S
    5,007
    1034 times
    In the video the chain seemed extremely loose. There should be only 30-45mm / 1.2"-1.8" at the tightest spot.
    Mine's never made that kind of noise when rotated by hand, but I have heard knocking when riding. Usually related to the chain being too loose or dry.
    As for the shiny spots mine had those too when I did my first swap from 16 to 17 teeth.
    I'd rather the sprocket wear than the chain as it's cheaper and easier to replace
    Up-And Comer Rescue119's Avatar
    May 2018
    Ontario, Canada
    78
    Did u grind the inside of the cover for going to 17t? It rubs if I don't.
    Sent from my LG-H873 using Tapatalk
Similar Threads
  1. Tick, tick, tick
    By jmeier1981 in forum General Mean Streak
    Last Post: 07-30-13, 06:02 AM
  2. Tick tick tick.. what is it?!
    By Meanie_Me in forum Mean Streak Maintenance
    Last Post: 07-19-10, 07:42 AM
  3. My Z's a-tick-tick-tickin'
    By Nix in forum Z1K/Z750 Maintenance
    Last Post: 09-05-07, 09:39 AM
  4. Tick, tick, tick, tick, tick...
    By kirk180 in forum General Z1000/Z750
    Last Post: 06-10-05, 12:10 PM
  5. tick-tick-tick
    By Jason Smith in forum ZR-7 Maintenance
    Last Post: 01-25-02, 02:36 PM
