FUEL blinking with full tank need help
This is a discussion on FUEL blinking with full tank need help within the General Z1000/Z750 forums, part of the Kawasaki Z1000, Ninja 1000, Z800, Z750 & Z-750S category; Hello, I have a 2005 ZX-10R with 12k on it. My bike is in mint condition with no previous issues. Yesterday I turned it on ...
Results 1 to 7 of 7
    Newbie seid2437's Avatar
    Jun 2019
    Hello, I have a 2005 ZX-10R with 12k on it. My bike is in mint condition with no previous issues. Yesterday I turned it on and the Fuel gauge came on while the word FUEL continued to blink on the speedometer. The tank is nearly full. I lifted the tank and checked all the fuel pump wiring, no bad or pinched wires. The bike starts and runs fine but the "FUEL" still blinks. Any help would be appreciated.
    Video of issue:
    Site Elder JustAJ's Avatar
    91343
    975
    36 times
    That probably means that the float inside the tank is stuck in the down position, assuming the fuel gauge on a bike works the same as a car one. Try rocking the bike left and right as hard as you can without tossing it onto its side - that might make it "unstick". Of course, the sensor could also be bad.
    Rising Star PerryG's Avatar
    195
    14 times
    Or the float sprung a leak, in which case no amount of shaking will help, check to make sure you have a good ground as well.
    Jun 2019
    Thank you for the replies. I will take out the fuel pump today and inspect it along with the float. All the lines to and from the gas tank seem to be in perfect condition. I will update if i figure this out.
    91343
    975
    36 times
    Quote Originally Posted by PerryG View Post
    Good point re leaking float!
    195
    14 times
    Ya just reminising back to the carbed days when we had a bunch of floats, screws with mixtures more when a carb float leaks
    Up-And Comer grinderdogg's Avatar
    Oct 2009
    Vermont
    56
    My 2007 z1000 has done this for two years now, when it gets low the fuel light comes on the. I fill up and it stays in for a while to maybe the next time I ride but does go off, I’m told it’s the sending unit but haven’t felt like replacing it yet.....
    Ride it like its going outta style!
