New Member and Some Questions about Turn Signals and Rear Light
This is a discussion on New Member and Some Questions about Turn Signals and Rear Light within the General Z1000/Z750 forums, part of the Kawasaki Z1000, Ninja 1000, Z800, Z750 & Z-750S category; Hey all, new to the forum here. Im from Whitby, Ontario and I just picked up a 2005 z750s and I'm looking forward to getting ...
Results 1 to 5 of 5
    Newbie hypoflow's Avatar
    Mar 2019
    Hey all, new to the forum here. Im from Whitby, Ontario and I just picked up a 2005 z750s and I'm looking forward to getting to ride it once the weather warms up and the snow melts.
    I'm looking at changing up all the turn signals and rear light on the bike as they are still the stock ones, plus some of the wiring is a mess so I'd like to clean that up. I know the tail end of the bike is shared with the 05 zx6r so I'm assuming that if I order a taillight that would fit the zx6r it should also fit my bike...correct? My other question is regarding the front turn signals. I discovered these turn signals that look pretty good and super bright (which I like). I've dealt with the cheap ebay kind before on my previous bike and I'd simply like something that people can see during the day and be super bright at night. The website of the company does not have lights listed for my bike but there are lights for a 2004 zx6r. After briefly looking at some google images of the 04 zx6r it looks like the front turn signals are the same so I'm assuming I'd be able to make these work. Any input on this? Also, side note but are the stock turn signals supposed to also operate as daytime running lights? I suspect one of the previous owners dropped my bike and replaced the turn signals with stock ones and did a horrible job at wiring them together.
    Here is a link to the front turn signals: Proton 500 LED Flushmount signals - Kawasaki
    Aug 2012
    Athens, Al
    146
    Z750s uses the first gen Zx10 tail light the standard Z uses the zx6 tail. As far as blinkers go basically anything should work just might need wired in and no the blinkers aren't wired from the factory as running lights
    Rising Star PerryG's Avatar
    183
    14 times
    Also a switch to led signal lights, if that's what you're doing requires a flasher change, leds draw less power so the bike thinks you have a burnt out bulb and the flasher doubles the flash rate (the stock flasher kind of tells you that you have a burnt bulb from the seat by looking at the dash arrows they'll speed up too, you'll lose this function so you should check your lights more often, I do a circle check myself before every ride due to this but it's a good idea to check stuff like this anyway). I don't remember the exact flasher I bought for my leds but with the one I have it's possible to use a integrated tail/signal light setup as well as keep led turn signals so you have both, still haven't gotten around to the integrated part myself but I will someday.
    Mar 2019
    Awesome thanks for the replies! If the front blinkers aren't wired to be day time running lights would there be any way to hook up the leds if they have the third wire for day time running lights or I am better off with just leaving it?
    Aug 2012
    Athens, Al
    146
    You'd just have to run your own wire from a switched hot. The closest is probably the running light at the top of the headlight
Similar Threads
  1. Replies: 3
    Last Post: 08-10-15, 11:39 AM
  2. Rear Turn Signals (turn to running lights)
    By muckdawg24 in forum General Mean Streak
    Last Post: 05-09-14, 11:39 AM
  3. WTB rear fender plastic piece and rear turn signals
    By rekit in forum Mean Streak For Sale/Trade
    Last Post: 11-23-09, 08:31 PM
  4. custom led rear turn signals and brake light
    By ryani in forum Z1K/Z750 Accessories
    Last Post: 08-31-05, 06:56 AM
  5. Rear light/turn signals
    By basher in forum Z1K/Z750 Performance Upgrades
    Last Post: 09-18-04, 07:08 AM
