Spitting out Coolant
This is a discussion on Spitting out Coolant within the General Ninja 650R forums, part of the Kawasaki Ninja 650R category; Hey Guys, I have '14 Ninja 650. I recently did a coolant flush and switched to Toyota Pink antifreeze. I filled up the reservoir a ...
Results 1 to 10 of 10
  • 1 Post By JustAJ
Thread: Spitting out Coolant
    Newbie redted's Avatar
    Sep 2018
    Saint Louis
    Hey Guys,
    I have '14 Ninja 650. I recently did a coolant flush and switched to Toyota Pink antifreeze. I filled up the reservoir a little above the "HI" line. I noticed a little bit of coolant spit out on the ground from the previous ride when I take it out. I did the flush at 8500mi, I'm at 9100mi now and have added 4-6 ounces of pink since then. Does this happen to any of you guy running non-Kawa coolant? Also my fan turns off when I turn the bike off - Do your bikes do that?
    Appreciate any insight, I'm taking an 800mi trip to Iowa for the 4th of July and I don't want to bring coolant with me.
    Up-And Comer CrateCookie's Avatar
    Houston, TX
    I haven't had that but did have the top of the reserve tank crack open due to sun damage to the clear plastic. That was about a year ago (my 650 is a 2013).
    Site Elder JustAJ's Avatar
    91343
    974
    36 times
    The only time I had it happen was when I was having issues with my radiator cap. It wasn't sealing properly so she'd spit. But it was also accompanied by a bubbling sound shortly after I shut it down. If it's only a little then don't worry. Having to add more after a flush is normal since there is always *some* air left in the works even if you fill it slowly and super carefully.
    Up-And Comer Balazar's Avatar
    May 2014
    60
    Quote Originally Posted by JustAJ View Post
    I have this exact same problem with the spitting and bubbling. How did you fix it? New cap?
    91343
    974
    36 times
    Quote Originally Posted by Balazar View Post
    Remove your radiator cap and put a light film of regular grease around the flat surface that seals to the radiator mouth. Bubbling noise means the cap is not sealing right, and apparently grease is required for it to function properly. If your bike is old / high mileage then it could be the cap, but I replaced 2 caps before my parts guy hit me with the tidbit about the grease. Haven't had an issue since, and I even put hte "old" cap back on.
    redted likes this.
    May 2014
    60
    Great tidbit. Thanks for sharing. I am planning to do a coolant flush and troubleshoot it this weekend. Glad I haven't bought a cap yet.
    Sep 2018
    Saint Louis
    Remove your radiator cap and put a light film of regular grease around the flat surface that seals to the radiator mouth. Bubbling noise means the cap is not sealing right, and apparently grease is required for it to function properly. If your bike is old / high mileage then it could be the cap, but I replaced 2 caps before my parts guy hit me with the tidbit about the grease. Haven't had an issue since, and I even put the "old" cap back on.
    My cap is sealed, good tip none the less. I tracked the pink drips from the ground up and I found the source of my leak: the band clap connecting a rubber tube to the water pump. I must have put it back on improperly after the flush. My bad.
    Supreme Being Ozninjaguy's Avatar
    Nov 2014
    Philippines
    64
    2,304
    548 times
    ....and yes, your thermo fan will turn off with the ignition.
    Nothing in all the world is more dangerous than sincere ignorance and conscientious stupidity - Martin Luther King Jnr.
    Up-And Comer passive101's Avatar
    Mar 2017
    Wisconsin
    97
    What type of grease can be used on the cap? I notice I'm leaking coolant on my 2017
    91343
    974
    36 times
    Regular old everyday grease. And just a tiny amount, enough to coat the rim in a thin layer so the parts don't stick.
Tags for this Thread
