Transmission issues?
This is a discussion on Transmission issues? within the General Ninja 650R forums, part of the Kawasaki Ninja 650R category; Hey guys I have a 2016 Ninja 650, I just noticed this today but I can shift gears without using the clutch (No quickshifter, nor ...
Results 1 to 9 of 9
    Newbie Felix's Avatar
    May 2018
    20
    Hey guys I have a 2016 Ninja 650, I just noticed this today but I can shift gears without using the clutch (No quickshifter, nor am I killing the throttle) I can literally push up on the lever and it'll change to the next gear, granted there is a slight resistance but I remember this being almost impossible to do. Is there something I could have possibly ruined? My clutch does not feel like its slipping.
    Sep 2018
    124
    I think its normal and expected because that’s what mine does( i think)
    2010 ER6NL ABS
    Site Elder JustAJ's Avatar
    91343
    974
    36 times
    This is perfectly normal. There are plenty of people who don't use their clutch for upshifting, both on bikes and cars. At the correct RPM range, it should be exactly as you described, a slight resistance but otherwise smooth.
    Newbie txhelgi's Avatar
    Jun 2008
    Grand Prairie TX (DFW)
    57
    AJ is spot on. I love to shift without the clutch. Just put light pressure on the pedal, find the correct rpm and it will slip right into the next gear.
    Site Elder scottmac99's Avatar
    Melbourne, Australia
    68
    984
    I third that. It feels rather nice when accelerating at speed.
    2000 ZR-7 (red, faster)
    2002 Royal Enfield Bullet 500 (black, definitely slower) ... yep still got 'em both
    Never give up. If you give up, you'll lose. If you don't give up, you might win.
    Up-And Comer xorbe's Avatar
    Sep 2013
    87
    15 times
    A quickshifter does this automatically, but otherwise apply pressure with the toe upward, and momentarily close and re-apply throttle, pretty easy. It seems a lot harder to me to emulate an auto-blipper (push and blip throttle for clutchless downshift).
    Newbie HitnRun's Avatar
    Jul 2018
    Bakersfield, CA
    51
    4
    I have a Versys 650 which is the same engine and I shift 1st and 2nd with clutch and after that I just it slides in just fine. Good skill to learn in case you break the clutch cable.
    Rising Star Baxter's Avatar
    Dec 2009
    Bismarck, N.D.
    487
    71 times
    What you described is either normal, or it's also a defect on my 2007.
    Your heading reminds me of a funny story. A few years ago I had noticed some sluggishness in my car's transmission. Internet research lead me to find that I needed to add about an pounce of transmission fluid to the car. That's not the story. The story is that while researching transmission problems--spelled out completely just that way--a site called Tranny Troubles showed up in the results. It was not about transmissions, or even motor vehicles, but it did feature a lot of sticks. That's what I get for not having parental controls active on my computer (no kids at home).
    Similarly, a friend was once looking up knitting sites without parental controls, and had some unexpected surprises in the results as well.
    2007 Ninja 650R. IBA: 2015 SS1000; 2016 SS1000/BB1500 combo
    91343
    974
    36 times
    Quote Originally Posted by Baxter View Post
    LOL! Try searching for "Public Records" and forgetting the L.
Tags for this Thread
