2007 650r not starting
This is a discussion on 2007 650r not starting within the General Ninja 650R forums, part of the Kawasaki Ninja 650R category; Hey guys, so I’m having this problem with my 650. I left it on a battery tender all winter and just recently put it off ...
Results 1 to 7 of 7
    Newbie Jake1h's Avatar
    Aug 2017
    18
    Hey guys, so I’m having this problem with my 650. I left it on a battery tender all winter and just recently put it off for 2 rides 2 days in a row. Now when I went to go out for my 3rd ride in this nice weather the bike will not start. The electrics are all over the place and when I go to start the bike it just clicks and goes off. I attached it to jumper cables and tried to get it running that way and while it did start the bike, it only worked while the cables were on. So as soon as I disconnect, the bike dies. This is a fairly new battery and the the battery tender says that it has plenty of charge. Anyone have any ideas on what may this be ? Weather is just getting nice again and I’m dying to get back on the road. I Appreciate the feedback in advance
    Up-And Comer JS_racer's Avatar
    Jun 2007
    Twin cities MN
    73
    Cables clean and tight? Click and goes off sounds like connections
    Whats the voltage in the battery
    Could also get the battery tested. Batteries plus and tons of other places test them. After looking at the connections and voltage.
    Jun 2007
    Twin cities MN
    73
    Have to toss a battery in my 650 in the next week or two myself, cranked slow and short last year, my tender jr took a dump. Have a plus, another jr ctek 4.3 and some bigger high end ones from when i was a mechanic
    Up-And Comer smknkeyz's Avatar
    Jul 2014
    Northeast US
    42
    Dead battery most likely, but I'd also check the stator.
    __________________
    2009 ER-6N
    Yoshi TRC-SS | Puig Screen | Puig Pro Sliders | Spools | PCV | BMC Filter | Aftermarket Mirrors | Evotech Radiator Guard | JPR Short Levers | Tidy Tail by s2r | Corbin Gunfighter & Lady seat | Progressive Rear Suspension | Progressive Front springs | Galfer SS Brake Lines | RSV Racing Rearsets | BRP 180 Rear Wheel Conversion
    Up-And Comer Timpo's Avatar
    Jun 2017
    71
    10 times
    yeah I would check the stator.
    From what I understand if stator is bad, it won't recharge the battery. Is the battery dead but it had its life? or is it dead because the stator isn't charging the battery?
    I'm guessing the rectifier/regulator could be the bad too.
    Supreme Being Ozninjaguy's Avatar
    Nov 2014
    Philippines
    64
    2,306
    549 times
    Quote Originally Posted by Jake1h View Post
    A battery might have the required voltage but not the required CCA's to start the bike - so it could be faulty. However, if you can start it with jumpers but it dies once the jumpers are removed then it's most likely a charging issue - Regulator/Rectifier and/or Stator because once running your bike is powered by the charging system, not the battery. Your bike is pretty old now and the 650 is well known for burning out Stators. Buy yourself a cheap multimeter and check R/R and Stator - it's a 5 minute job and there are heaps of vids on Youtube on how to do it.
    Nothing in all the world is more dangerous than sincere ignorance and conscientious stupidity - Martin Luther King Jnr.
    Site Elder electjohn's Avatar
    Jan 2007
    North East Ohio
    77
    705
    15 times
    CCA"s is at best and iffy number,all batteries have a made up number reserve capacity is the only true number and it is put on the battery case figure one dollar for one amp roughly what you will pay.
Similar Threads
  1. 2007 ninja 650 troubles starting
    By witchered in forum Ninja 650R Maintenance
    Last Post: 03-30-16, 10:39 AM
  2. roll starting / bump starting the n1k
    By treestone27 in forum 3rd Gen Z1000/Z1000SX/Ninja 1000
    Last Post: 05-11-15, 02:11 PM
  3. 2007 650 not starting
    By das_napeth in forum Ninja 650R Maintenance
    Last Post: 04-23-14, 07:35 AM
  4. My 2006 650R not starting... any suggestions???
    By tthinn in forum Ninja 650R Maintenance
    Last Post: 04-08-14, 08:20 PM
  5. zr-7 not starting
    By tln708726 in forum ZR-7 Maintenance
    Last Post: 04-20-05, 07:59 PM
2007 ninja 650r regulator problems
kawasaki 650r starting problem
ninja 650 not starting
ninja 650 rectifier location
