2017 Ninja 650 Clip-ons ?
This is a discussion on 2017 Ninja 650 Clip-ons ? within the General Ninja 650R forums, part of the Kawasaki Ninja 650R category; Any news when different bars may be available for the 2017. I'd really like something lower and with less sweep. Preferably adjustable. Currently thinking ok ...
Results 1 to 15 of 16
Thread: 2017 Ninja 650 Clip-ons ?
    Newbie Mxdad32's Avatar
    Aug 2017
    Middle Tennessee
    14
    Any news when different bars may be available for the 2017. I'd really like something lower and with less sweep. Preferably adjustable. Currently thinking ok some Woodcraft 3" rise clip-ons mounted below the top triple using their riser spacer to clear the front mounted fork pinch bolt. Anyone see a problem with doing this? Any other options? Don't really want top mount as I'd have to slide the forks up and would prefer to keep them where they are.
    Newbie Garrthomp6's Avatar
    Feb 2018
    I’m about to buy the 2018 Krt and I’ve found every thing I could possibly want to do to this bike BUT the handlebars. I was considering doing the same thing. Let me know if that works out for you. I want lower bars but I don’t want to hit the tank or front fairings.
    Rising Star MillennialNinja's Avatar
    Jan 2018
    282
    47 times
    I'm interested in this too. I'm sure it's possible, I'm just not willing to play the ebay-roulette until I know a model is compatible for sure. I'd appreciate the adjust-ability, but I'm not that desperate for the feature.
    10,304
    2255 times
    Look up "laverda adjustable bars"
    I have them and I tried them on my '07 Ninja but the fairing and the tank really limit the amount of adjust-ability available on that bike. They work great on UJMs.
    You are not that far from me. Maybe we could get together one saturday and we could see how they would mount up on your bike.
    Up-And Comer Timpo's Avatar
    Jun 2017
    71
    10 times
    In my opinion, I wouldn't bother.
    I could see why you would be looking for a sportier handle bar only if you had a 2016 Ninja 650.
    The difference between 2017 & 2016 Ninja 650:
    2017 Ninja 650's handle bar position has been lowered by 42mm and moved 25mm forward.
    (Interestingly, 2017 Ninja 650 has 15mm lower seat height and foot pegs have been moved 60mm forward and lowered by 15mm, which is less sporty)
    Anyways, I picked the 2017 Ninja 650 because I felt the 2016 Ninja 650 was not sporty enough despite being on clearance sale, I didn't want one.
    Also the Z650 is virtually identical to Ninja 650 but has higher handle bar, so the Ninja 650's bars a bit lowered anyways.
    But those statements above do not answer your question, so here goes.
    I do not think Woodcraft clipons with riser would work. You know how they get mounted right? The bars will be moved forward and lowered.
    I just went outside and tried to steer all the way to left and right, and if I get a woodcraft clip on, it would be too close to the fairings & it would hit the front windshield. (I have OEM tall windscreen so maybe that's why, but still...)
    The Ninja 400 handle bar might work, and because of its flar profile, you would not have to raise the fork as much, but as you can see, it requires additional bolt to make it stable... I don't know if you can drill a hole or if it's possible to come up with another solution.
    Jun 2017
    71
    10 times
    actually never mind, the Ninja 400 might have smaller fork diameter
    Rising Star 2012 Ninja 650's Avatar
    May 2012
    Connecticut
    427
    33 times
    I have a 2012 and would love to put the 2017 bars on mind. Would that work?
    Work Hard...Play Hard!!!
    Jan 2018
    282
    47 times
    Quote Originally Posted by 2012 Ninja 650 View Post
    Nope.
    Edit: Looks like Timpo may be right (read next post). I was only thinking about changing the bar itself. You'd have to swap the whole assembly, which would be pretty expensive if undamaged, but it might be possible. I'd like to think the spacing is the name, and it should be, but you never know. If this really, really interests you, it might be worth checking out.
    Jun 2017
    71
    10 times
    Possibly yes.
    As you can see, the 2016 and 2017 Ninja 650 handlebars are both mounted by two bolts.
    2016
    https://www.bikebandit.com/oem-parts..._BwE#sch941894
    2017
    https://www.bikebandit.com/oem-parts...9414sch1014658
    They have very similar structure and mounting position is very similar, it might be identical.
    Just by looking at it, they do have identical handlebar damper (part #92161) which tells me that the diameter of mounting hole is probably identical.
    Judging by the diagram, the mounting positing might be identical too.
    If not, you might have to purchase the top triple tree holder so that you can mount the 2017 handle bar if it fits.
    Jun 2017
    71
    10 times
    Sorry for multiple posts, but I'm just posting this is make a point..
    Due to high demand, Beet just introduced the bar riser.
    As you know, the 2017 Ninja 650's handle bar has been lowered significantly compare to the previous generations. Which is not everyone's cup of tea.
    Anyways, I don't think lowering the 2017 handle bar even more does not make much sense, I know it's each to their own, but it is NOT a ZX-6R.
    xorbe likes this.
    Jan 2018
    282
    47 times
    Quote Originally Posted by Timpo View Post
    Haha And to think that while I was riding earlier today I was thinking "You know, I wouldn't mind a less upright position one bit...". Oh well.
    - Check out my 2017 Ninja 650's Mods & Upgrades!
    - If you're looking for some new projects, I've got a few interesting motorcycle DIYs.
    Up-And Comer xorbe's Avatar
    Sep 2013
    84
    15 times
    If I wanted supersport position, my god I would have an R1 in a heartbeat (for the cross plane crank, love that engine sound).
    Thanks Timpo, I may actually get that riser.
    Aug 2017
    Middle Tennessee
    14
    Haven't been on here for a while. Want to respond to some of the comments. First I have long arms and the stock bars have too much sweep for me putting my wrists in a painful position. There is no way at all to adjust the stock bars. What I would love to have is a bar that is about an inch farther forward at the endsby taking out sweep to accomplish that. I would also like a bar that is 1-1.5 inches lower at the ends by way of having a downward angle, less flat bar. This would put me in much better position for aggressive cornering In twisties. I love the rest of the bike, I neither want or need a ZX6R. I would just like some adjustability to accommodate the ergonomics I am looking for. For much the same reason I don't like the sportbars or the woodcraft version either.
    Sep 2013
    84
    15 times
    Does anyone actually import that BEET riser into the USA? All the pages are in Japanese.
    Jun 2017
    71
    10 times
    Quote Originally Posted by xorbe View Post
    I know https://www.samurider.com/ has really good reputation with their customer service.
    You might want to contact them and see if they're able to get it? I heard really good things about them.
    Also Webike might be able to get it, they're pretty big, the Revzilla of Japan.
    I couldn't find the 2017 Ninja handle bar though.. https://japan.webike.net/bm/brd/Hand.../BEET/1044/85/
2017 inja 650 clip ons
2017 kawasaki ninja 650 handlebar risers
2017 ninja 650 bar risers
clipons ninja 650
ninja 650 2017-2018 lowing bars clip ons
ninja 650 2018 clip ons
ninja 650 clip ons
ninja 650 clipons
ninja 650 forks
ninja 650r 2018 clipons
