Transmission problems
This is a discussion on Transmission problems within the General Mean Streak forums, part of the Kawasaki Mean Streak category; I have a 2007 Mean Streak 1600 that is giving me transmission problems. Long story short, it has been stored in my heated garage on ...
Results 1 to 7 of 7
  • 1 Post By ChrisS
Thread: Transmission problems
    Up-And Comer ChrisS's Avatar
    Jul 2011
    West Virginia
    40
    14 times
    I have a 2007 Mean Streak 1600 that is giving me transmission problems. Long story short, it has been stored in my heated garage on a battery tender for 2 years without being started. Yesterday I went out and started it. It started right up and I let it get up to temperature before trying to move it. When I put it into 1st it immediately killed the engine. I put it in neutral and it fired right back up. I shut it off and got on here and looked for anything related to my issue and came up with frozen clutch discs. I went back out and fired it up and let the oil get nice and hot and pumped the hell out of the clutch lever and then shut it off and wrapped a bungee cord around the clutch lever and turned it off and let it sit overnight. Today I went back out and pumped the hell out of the clutch before even starting it up. After starting it up, it went right into first. I then put it in neutral and noticed it creeped forward a bit with the clutch level pulled in. My issue is I have no gears from 2nd to 5th. Does anyone think the clutch discs could still be sticking or do I have an issue inside the transmission? I never had any transmission issues when I parked it. I’m hoping a simple clutch replacement will fix my problem before I end up pulling the engine and transmission for a tear down. Any suggestions or recommendations would be greatly appreciated. Thanks for any help in advance.
    Sent from my iPad using Tapatalk
    2007 Kawasaki Mean Streak 1600
    Cobra Speedster shorts
    Baron's Coaster plates
    Caddman mod.
    Cobra FI 2000r fuel management system
    Kuryakyn Hypercharger
    Batwing Fairing
    Purple led lights
    B46
    B46 is offline
    Rising Star B46's Avatar
    Sep 2012
    156
    150 times
    If you mean that you don't have 2nd thru 5th with the bike sitting still, that is normal. I think they call it "positive neutral" - it prevents the transmission from shifting from 1st into 2nd when the bike is at a standstill. Once the bike is moving, the system is disengaged and you can shift all you want. In addition to helping the rider find neutral, I guess it also helps prevent the rider from starting out in a gear that could stall the motor.
    The issue of your bike stalling as soon as you put it in 1st (after it had been stored for 2 years) is also pretty normal. Sticking clutch plates. I have learned that when I first put my bike in 1st, I need to have a pretty good grip on the front brake - otherwise it will sometimes lurch forward quite a bit.
    Bottom line, I think you just need to ride more!
    Cheers!
    Tom
    '05 Mean Streak, '07 DRZ-400S, '01 Bandit 1200S
    Jul 2011
    West Virginia
    40
    14 times
    Thank you. If the rain ever stops I might be able to ride it. Looks like another rainy summer in WV.
    Sent from my iPhone using Tapatalk
    Caddman mod.
    Batwing Fairing
    Purple led lights
    Jul 2011
    West Virginia
    40
    14 times
    Hey B46. Just wanted to let you know I put some Seafoam in the oil and got it hot and changed the oil and it’s shifting great. My girlfriend and I put 200 miles on it yesterday. Thanks for your help.
    B46 likes this.
    Caddman mod.
    Batwing Fairing
    Purple led lights
    B46
    B46 is offline
    Sep 2012
    156
    150 times
    Good deal! Enjoy your bike!
    Riding is a crucial part of maintaining my sanity. Ride more, worry less.
    Cheers!
    Tom
    Up-And Comer Ponkster45's Avatar
    Apr 2014
    N E Scotland
    127
    86 times
    A sticking sidestand switch will kill the engine when you put it in first !
    Have you tried riding it in first to free up the plates - if its been sitting a while you may not be able to shift up the box with the bike sitting still - it sound like the clutch plates are dragging which is the creeeping forward thing - the plates have been stuck together for a long time and need a good trash to get them apart.
    I do think it does sound like clutch which is no big deal - dont go splitting boxes and **** like that !
    Jul 2011
    West Virginia
    40
    14 times
    Thank you. I got it fixed. Put about 2 shot glasses of Seafoam in the oil and let it get good and hot and ran the **** out of it. I then changed out the oil and have been running it ever since.
    Caddman mod.
    Batwing Fairing
    Purple led lights
Similar Threads
  1. Transmission problems?
    By Hellbeast in forum General Ninja 650R
    Last Post: 05-29-15, 05:17 PM
  2. Transmission Problems?
    By cbissette in forum General Mean Streak
    Last Post: 06-12-09, 01:27 PM
  3. Transmission problems
    By mephisto613 in forum General Mean Streak
    Last Post: 04-25-07, 07:52 PM
  4. Locked up transmission
    By Azzip in forum General ZR-7
    Last Post: 04-02-04, 10:48 AM
  5. Transmission trouble?
    By twhite in forum ZR-7 Maintenance
    Last Post: 04-30-02, 08:39 PM
