2015 Versys 1000LT Slipper clutch... would it fit ????
This is a discussion on 2015 Versys 1000LT Slipper clutch... would it fit ???? within the 4th Gen Z1000/Ninja 1000 forums, part of the Kawasaki Z1000, Ninja 1000, Z800, Z750 & Z-750S category; Hey Guys, Just saw that the Versys 1000 2015 has a slipper clutch and we don't....... You think it would fit in our beasts ? ...
Page 1 of 18 1234511 ... LastLast
Results 1 to 15 of 264
Like Tree21Likes
Thread: 2015 Versys 1000LT Slipper clutch... would it fit ????
    Up-And Comer the0nlytruth's Avatar
    Quebec City, Canada
    31
    88
    10 times
    Hey Guys,
    t0t
    2014 Ninja 1000 ABS Candy Lime Green, accessories list to come.
    Supreme Being Chrispy's Avatar
    Sep 2013
    Montreal
    1,209
    121 times
    Subscribed..........
    I haven't studied the online fiche but it can't be too difficult to make work....... First question is the primary gear the same?
    Supporting Member THEMANRACING's Avatar
    Moore Oklahoma
    4,318
    751 times
    I bet it can be made to fit. But it will be a few years till you see some smashed up Verseys where you can get the assembly for a reasonable price, IMHO.
    Interestingly the Verseys has 10.3 to 1 compression, where as the Ninja has 11.8 to 1. A point and a half is stupid huge.
    I want to bump my Ninja 1.2 points over stock...lol
    8,690
    1569 times
    Jay, I'll bet you can do the compression raising..I remember workign with the honda crf 450's that the compression was one part of the story, but cam shape, and duration played a role too in cylinder pressure and avoiding detonation.
    As you said, its probably $$$$ until some used parts come on to the market. I think the ninja is owned by older folks who dont crash much. So far we've not seen much in used parts. The Versys will be worse.
    OK, so back to a search....2015 Versys clutch Looks like a few parts are shared with us.
    2015 Kawasaki VERSYS 1000 (KLZ1000BFF) Clutch | Babbitts Kawasaki Parts House
    The clutch inner hub, itself, appears to be the same as always. The clutch housing (basket) is
    too...
    13095-0118 Partzilla Search
    13095-0118 HOUSING-COMP-CLUTCH $430.89
    At least two familiar parts.....
    Quebec City, Canada
    31
    88
    10 times
    Quote Originally Posted by Chrispy View Post
    Pretty sure i've read it is shorter on the Versys.
    Moore Oklahoma
    4,318
    751 times
    Quote Originally Posted by the0nlytruth View Post
    I could be wrong, but I think you guys are talking about different things. I believe Chrispy is talking about the gear stuck to the back of the clutch basket itself, and I believe you are talking about the transmission/overall gearing for the bike.
    Moore Oklahoma
    4,318
    751 times
    RC I am confused by your search results. It looks like two different searches for the same part? The clutch basket?
    That the clutch basket is the same is awesome. That will make a retro fit cheaper, and means the answer to Chrispy's question is a tentative yes, the primary is the same.
    From looking at the Microfiche that RC provided, it looks like the slipper is operated by the inner hub and pressure plate. That would look to be a reasonably simple swap.
    The question would be how well does it actually work.
    8,690
    1569 times
    That search was confusing to me. Its not finished, obviously, but if someone else wants to take over...
    It was nice to see a few shared parts. I'm thinking it could be possible. I was excited when the expensive part, the 430.00 one, was shared between our bikes.
    That would be the gear we were concerned with.
    Quebec City, Canada
    31
    88
    10 times
    1000$ for an aftermarket slipper clutch is way too much, but if we can do this for few hundreds by swapping parts with the Versys, I might be in
    Moore Oklahoma
    4,318
    751 times
    Looks like the deal is $400 to $500 on top of a clutch change (the only reasonable time to do it in my own opinion). Thats still pretty pricey. IMHO.
    8,690
    1569 times
    Jay, what all do we need to buy?
    Up-And Comer levesl's Avatar
    Sep 2012
    Baie Comeau Qc (Canada)
    55
    Involve changing a lots of parts. I may have not seen all of them!
    Look like this. Subtotal: $819.92
    HUB-CLUTCH
    Kawasaki
    item: 13087-0566 $207.87 1 $207.87
    PLATE-FRICTION
    Kawasaki
    item: 13088-0568 $19.48 9 $175.32
    PLATE-CLUTCH,T=2.3
    Kawasaki
    item: 13089-0023 $12.58 1 $12.58
    PLATE-CLUTCH,SPG COMP
    Kawasaki
    item: 13089-0024 $12.58 1 $12.58
    PLATE-CLUTCH,T=2.3
    Kawasaki
    item: 13089-1084 $11.00 6 $66.00
    PLATE-CLUTCH OPERATING
    Kawasaki
    item: 13187-0023 $108.47 1 $108.47
    PLATE
    Kawasaki
    item: 13272-1413 $10.85 1 $10.85
    SEAT-SPRING
    Kawasaki
    item: 16007-0711 $3.26 3 $9.78
    SPRING
    Kawasaki
    item: 92145-1630 $5.87 3 $17.61
    COVER-CLUTCH
    Kawasaki
    item: 14032-0590 $198.86 1 $198.86
    Subtotal: $819.92
    Moore Oklahoma
    4,318
    751 times
    Looks to me like the inner hub and the pressure plate, along with the springs and plate that is near the springs.
    Thats my opinion, but I would really need to have one of each in my hands to look at it.
    I have done something similar before. I put a slipper out of an 06 G1k into my buddies 04 G1k.
    As far as clutch plates, i bet the ones from the ninja would work. I would be certain the friction plates would work, and have reasonable confidence that the steels would work as well. But again I think this mod makes the most sense when it time to replace the clutch anyway.
    8,690
    1569 times
    Levesl, thanks for digging in like that. Its a pain in the ***.
    Interesting search for part number 13089-0023. It comes up as being for the zx6r. (plates)
    13089-1084 shows fitting the zx6, zx9, our bikes and others... (plates again)
    Could it be this slipper really is not that special, and just might be from the zx6/zx10?
    The 14032-0590 is the outer cover and 190.00. This often shows up as fitting the 2014 z1000. It might just be a paint only change since that bike has no slipper.
    I'm thinking levesl list is correct, but we might be able to delete a few high dollar items, or re use some of what we have. Even if we cut 190 bucks from the outer cover, thats a big deal.
    Moore Oklahoma
    4,318
    751 times
    I just ordered the parts I thought I would need to do it. It was $365 and change. Should be here in a couple weeks. I will try and do a how-to when the parts come in, as well as an actual parts list.
    Hopefully none of the parts are on back order.
    rcannon409 and the0nlytruth like this.
2015 kawasaki versys 1000 forum
how well did the kawasaki versys 1000 sale in the us 2015
kawasaki ninja 1000 slipper clutch
kawasaki versys slipper clutch
klz1000bff hub clutch
penske fork kit kawasaki versys 1000
rider forums versys 1000 slipper
versys 1000 forums
versys 1000 slipper clutch for ninja 1000
