ZRX1200 DAEG
ZRX1200 DAEG
This is a discussion on ZRX1200 DAEG within the ZRX Land forums, part of the Other Bikes category; I'm a japanese member who doesn't post often here. Just for your information. ZRX1200 DAEG http://www.kawasaki-motors.com/model...daeg/index.jsp (photo added) multi reflector headlight wave disc brake four ...
Results 1 to 12 of 12
Thread: ZRX1200 DAEG
    Newbie LSWer's Avatar
    Nov 2006
    6
    ZRX1200 DAEG
    ZRX1200 DAEG
    (photo added)
    wave disc brake
    four pot brake
    winker design change
    LED tail light
    large radiator
    lighter wheel
    seat change
    meter change
    injection
    D shape swing arm
    suspension change
    exhaust shape change
    6 speed transmission
    (From a magazine I bought today with my translation)
    There is not an export version for new ZRX1200 DAEG. Namely, this is a japanese standard naked developped only for japanese riders. We'll write test ride impression soon. We'll introduce this bike now.
    Front brakes are new 4 pot caliper(Ex was 6 pot). 310mm(rear:250mm) petal disc rotars look good. Wheels for ZZR1400 also look good. Front and Rear suspensions were totally refined with their settings. Rear shocks applied 2 stage spring, and manage both initial softness and toughness at high load. Attach point at the bottom moved 20mm backward and by being laid down, enabled good move. Swing arm with "D" shape is a newly developped part, chain adjustar is excentric type as ex model. Down sized chain(530->525) contribute to low noize and lightness. Fuel was changed from regular to premium in order to acquire enriched power feel at practical use range. The bike we photographed this time is a preceeding production model, some small changes like smoothening exhaust joint part, changing meter materials etc will be applied for production model from 02/09.
    Celebrating eddie lawson winning AMA superbike in 1981, KZ1000R1 : lawson replica was sold next year. Bikini cowl surrounding four-sided head light, edge shaped fuel tank and tail cowl...
    Motifing KZ1000R1, 400cc ZRX appeared in 1994. In 12/1996 ZRX1100 has debuted with remade GPZ1100 engine. In 2001, it souped up to 1200. The well-received styling wasn't changed for 12 years.
    Severe unti noise/exhaust regulations has scale-downed japanese domestic market, but kawasaki decided to make ZRX1200 a domestic only model!
    Luckily ZZR1400/Z1000/Z750 are in good sales in europe. On the other hand, presence of ZRX hardly makes itself felt which isn't full-cowled tourer nor extreme naked : street fighter.
    Then let's realize best performance for japanese roads and styling japanese riders like. The vector of development has be settled.
    Max power has become 110PS adding 15PS with pursueing flexibility. Outer parts are also reformed and appeals strongly. This progress is the DAEG. : runic alphabet which means progress.
    6 speed Transmission was newly developped basing ZZR1200 unit(Ex model was 5 speed). Radiator was lightened 340g, cooling performance has improved 16%.
    Meters have 2 LCD panels which indicate left fuel litre, clock, trip meter. Red zone is from 9500rpm. Immobiliser is standardized.
    Seat has become slim but it has enough thickness in both front and rear.
    Bikini cowl shape has become sharp and edged one, really looks like GPZ900R ninja.
    Under seat space is enough for rain wear and small baggage. 2nd helmet holder is a hook welded on the frame.
    There are baggage hooks which slides 5cms under the tail cowl.
    bore 79.0 stroke 59.4 1164cc compression ratio 10.1 Fuel injection
    81kw<110ps>/8000rpm
    107Nm<10.9kgm>/6000rpm
    6speed return : 2.733/1.947/1.590/1.333/1.153/1.035
    primary/secondary : 1.615/2.444
    length : 2150
    width : 770
    height : 1155
    wheelbase : 1470
    bottom height : 135
    seat height : 790
    caster/trail : 24-30/100mm
    tyre : F:120/70ZR17 R:180/55ZR17
    weight : 246kg
    fuel tank : 18L(premium)
    fuel consumption : 25.8km/L (60km/h)
    Supreme Being Zammy's Avatar
    Jun 2003
    Decatur ,Al
    60
    1,854
    COOL !!!
    Super Moderators
    groovyone's Avatar
    Aug 2003
    Dickinson, TX
    6,456
    Very sweet. Thanks for sharing!
    Your road determines your destination
    - Unknown
    If you don't know where you are going, any road will get you there.
    - Lewis Carroll
    Up-And Comer jagr's Avatar
    Nov 2008
    Central Ohio
    42
    116
    That is an awesome machine. I appreciate you posting it. Thank you.
    03 Kawi Z1000 (rebuilding)
    06 Zuki SV650S
    Rising Star FlaZR-7s's Avatar
    Oct 2006
    Cocoa, Florida
    52
    190
    To bad the U.S. will never see it.
    ZR7OA Member#: 1610
    2001 ZRX1200
    2003 ZR-7s
    Full Muzzy w/ Ivan's needles, Spiegles front brake lines.
    Galfer Wavy Rotors and pads.
    Progressive Fork springs, Vortex gas cap
    Zero Gravity Sport Screen, Hugger
    Super Moderators
    groovyone's Avatar
    Aug 2003
    Dickinson, TX
    6,456
    Quote Originally Posted by FlaZR-7s View Post
    Sad indeed. I wanted a ZRex before too. Could have completed the 2000-2003 set at the time with the ZR7, Z1k and ZRex.
    - Unknown
    - Lewis Carroll
    Supreme Being Azweepay's Avatar
    Feb 2008
    Panama City, FL
    53
    1,085
    That's awesome! I've always liked the ZRX but this one's even better, wish it'd come to the states. Love the solid color scheme. Not too crazy about the new sharper edged fairing but could live with it. Only thing I don't like are the shiny (chrome?) rad covers, but powdercoat those suckers black and she'd be good to go.
    Up-And Comer rbesr's Avatar
    Apr 2005
    135
    My kid brother has two Rexes, an '01 and an '05. I'd sure be interested in picking up a new one to add to the stable here. Hopefully they'll come to the US in a year or two.
    Brent Evans
    The Stable
    1999 Yamaha Venture
    2007 Yamaha FZ6
    Newbie Ladis's Avatar
    Jan 2009
    Czech Republic
    37
    24
    Question
    Like you said in Europe as well!
    Its big injustice...why Japanese riders can have brand-new bikes from Kawasaki Heavy Industries and rest of the world can only grudge?!
    ZR 750 F3 (ZR-7) '02
    Site Elder z1000pwnr's Avatar
    Dec 2007
    500
    i love that old skewl styling
    Rising Star SFTripod's Avatar
    Jun 2008
    San Francisco Bay Area
    449
    Hey Z1000pwnr,
    Quote Originally Posted by z1000pwnr View Post
    When you've got something that works, why change it? Although dropping a few pounds never hurts.......thought you might like this pic.
    Newbie 21FastEddie's Avatar
    May 2012
    4
    Love how the headlight fairing has the old NINJA jutting bottom edge!
kawasaki daeg
kawasaki zrx 1200 daeg
kawasaki zrx malaysia
kawasaki zrx1200 daeg review
kawasaki zrx1200 daeg top speed
zrx daeg
zrx1200 daeg
zrx1200 daeg review
zxr1200 daeg
