How to build a ZR-7e(s) - Page 2
This is a discussion on How to build a ZR-7e(s) within the ZR-7 Performance Upgrades forums, part of the Kawasaki ZR-7 category; Think you're out of luck mate - nothing known that will fit the OEM forks as far as I know....
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 72
Thread: How to build a ZR-7e(s)
    Up-And Comer DEcosse's Avatar
    May 2005
    Bay Area CA
    57
  2. #17
    Up-And Comer colsan1's Avatar
    Mar 2005
    nr manchester,UK
    54
    64
    Then let the search commence, i'll let y'all know when i find em.
  3. #18
    Newbie Hagafan's Avatar
    Jun 2010
    Cornwall, England
    6
    Good info, looking foreward to doing mod on my ZR7
    Site Elder pattonme's Avatar
    Jul 2002
    Alexandria, VA
    900
    I'm still around
    the zr7s is no longer in my possession but I can answer questions.
  6. #20
    Jun 2010
    Cornwall, England
    6
    Fork replacement
    I am just about to upgrade my front end with ZZR600E forks and nissin 4 pot calipers. will let you know how I get on. I was inspired by this thread.
  7. #21
    Jun 2010
    Cornwall, England
    6
    Front end done, great improvement. Next job to fit the ZX6R rear shock.
  8. #22
    Rising Star adamsjd's Avatar
    Sep 2006
    Nova Scotia, Canada
    37
    177
    I believe the original photo posting at http://f1.pg.photos.yahoo.com/ph/pattonme/ is no longer working. I wonder if it would be worth while posting the photos as attachments so the info doesn't get lost?
  9. #23
    Rising Star Wado750's Avatar
    Feb 2005
    Perth, Australia
    39
    467
    8 times
    Has any one else done the zx6r fork mod?
    Neil
    Yamaha FZ8S
  10. #24
    Up-And Comer Bike Tech AZ's Avatar
    Jun 2012
    Arizona
    61
    i havent done a zx6r fork mod....but i just gotting finished fitting and installing a 2001 zx-9 complete front end....IMG_20120602_193019.jpgIMG_20120602_192931.jpg
  11. #25
    Feb 2005
    Perth, Australia
    39
    467
    8 times
    I'm just going to cheat and fit the whole zx6r front end. That way I don't need to worry about spacers and can get back on the road quickly too. Looking at a set this weekend that is already fitted with racetech springs.
    Neil
    Yamaha FZ8S
  12. #26
    2,199
    180 times
    thats the easy way to do it on ANY bike..assuming you dont run into tree bearing issues
  13. #27
    Feb 2005
    Perth, Australia
    39
    467
    8 times
    This is were I'm up too. The forks are from a 95 ZX6R. It comes fitted with a race tech spring and has been revalved so there should be an amzing difference over standard. I got a whole front end, would I be better off using the rotors off the ZX6R wheel or just keep the ZR 7 rotors? I'm just waiting for a spacer and 2 sleeves to be made up.
    Neil
    Yamaha FZ8S
  14. #28
    Jun 2012
    Arizona
    61
    wo wo guys....cheat?...putting a zx9 front end on a zr7?...lol.....if you only knew what i had to do to get that front end on...a little more than have a few spacers made up....seriously...it was more work than i thought....here is what i had to do...the steering stem on the zx9 is about an inch shorter the the zr7...and also fatter....i had to turn down the stem on a lathe to accept zr7 bearings....i used the zx9 top triple clamp nut as the bearing preload nut...(radically modified on lathe and bridge port)...i also had to flip the top triple clamp over for it to drop down and have the clip on in a position i wanted...the made some spacers for under the triple clamp so it wouldnt hit the frame....had to tap the stem hole to use a cbr 929 front axle bolt as the triple clamp bolt...and finially...mo down the steering stops on the frame of the zr and weld on a stop that sticks out further because of the stops on thezx9 triple tree are farther apart....again i am furtunate enough to have access to the machines and the parts i aquired were on a barter system...my labor time for parts...it wasnt easy...but i got it doneIMG_20120524_213657.jpgIMG_20120526_142217.jpgIMG_20120602_192918.jpgIMG_20120602_193426.jpg
    [SIGPIC][/SIGPIC]2001 ZR-7s, evolving into what will be a ZR9-R....As of right now... ZX-9 complete front end, 636 swing arm + shock, undertail exhaust- 636 tail pipe with Two-Brothers carbon can, cbr600 heat shield, R6 rearsets, ZX12 windscreen, CBR1000 steering damper...still workn on...ZX-9 rear wheel install, 38mm mikuni adaptor plate, ram-air air box + finish duct work, zx-9 tailsection, modify a ZX-9 muzzy head pipe to fit and more.....and thats only the chassis... I have big plans for the motor also....
  15. #29
    Feb 2005
    Perth, Australia
    39
    467
    8 times
    Yeah I know, cheat was the wrong choice of words but I was refering to my install. Yours looked alot more completcated before your explanation. I found it much easier to get some sleeves and spacers made up in the end.
    Neil
    Yamaha FZ8S
  16. #30
    Newbie westdj's Avatar
    May 2012
    England, Bath
    11
    Could anyone tell me what spacers etc I should have on the wheel spindle! Previous owner had done the fork upgrade, I have zzr600e forks and 4 pot calipers but not convinced the disc is centre of the caliper.
03 kawasaki zr 7 white smoke from exhaust
fz8s oem mirror
kawasaki swing arm measurements
kawasaki zr-7 install front wheel
kawasaki zr7 engine life
zr 7 kawasaki wheel
zr-7 swingarm dimentions
zr-7s forks
zr7 to zx6e forks which progressive spring
zr7 vs zx6r
