K&n upgrade
K&n upgrade
This is a discussion on K&n upgrade within the ZR-7 Performance Upgrades forums, part of the Kawasaki ZR-7 category; I installed a k &n filter and also cut holes in the sides of air box and now bike doesn't want to rev up. I ...
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By Obo
  • 1 Post By Ronfra
Thread: K&n upgrade
    Newbie Ronfra's Avatar
    Apr 2017
    9
    K&n upgrade
    I installed a k &n filter and also cut holes in the sides of air box and now bike doesn't want to rev up. I know I need to get a jet kit to riches fuel mixture, any suggestion from someone that has simular mods on their zr7s.....Thanks in advance.
    4,547
    917 times
    Cutting holes in the airbox will cause it to bog down with the stock jets, just like if you try and run it with the airbox or filter off.
    In the meantime you'll either have to plug the holes or wait until you can buy a jet kit.
    WERA689 likes this.
    1,693
    567 times
    Most people will just add holes to the lid of the air box. Just to be sure that the problem is too much air, try plugging up the holes you made and make sure the bike will run as before, so it proves that alone is your problem. (If not, look at a air leak elsewhere) I'd recommend the Ivans jet kit.
    Admin
    WERA689's Avatar
    Nov 2011
    46
    20 times
    yep...if you change airflow in, you change the jetting requirements. Same applies for exhausts. Any time you change the ratio of fuel to air, you have to adjust the metering to get it back where it should be.
    4,547
    917 times
    I was a little worried when he said the holes ere added to the sides vs the top which is what I've seen recommended elsewhere. Don't know if it would really make any difference (assuming the jetting was done.)
    1,693
    567 times
    I was also eluding to the possibility that if the air box was removed to drill the holes in the side, if maybe the boots weren't correctly seated back in the air box when re-installed?
    Nottingham(UK)
    1,247
    269 times
    Open up the intake by taking the white piece out. take the top off and add some holes to the inside cover that has to 2 small inlets to the airbox.
    But don't drill holes in the sides facing the side panels, you are just inviting water to get in.
    I did put a few extra hole in the back where its facing the battery box, as that it protected from the weather.
    pic shows where.
    BUT DON'T DO ANY OF THIS TILL YOU HAVE A JET KIT FITTED
    Kawasaki ZR7
    4,547
    917 times
    Quote Originally Posted by shakennstirred View Post
    Think it's too late. If so I'd suggest covering the holes with duct tape for the time being.
    Mar 2004
    Delaware
    1,035
    36 times
    Yeah, the K&N isn't an "upgrade" unless you're installing a jet kit at the same time; just the opposite. Same for most intake/exhaust mods.
    2015 Versys 650 ABS
    (Former owner 2003 ZR-7S)
    Mods/Farkles: Puig "Touring" windscreen, Givi hand guards, BMW Sport Grips, Omni-Cruise throttle lock, Motowerk mirror extenders, SW-Motech gas cap mount tankbag, Denali Mini Soundbomb horn, Mag-Knight tank pad, SW-Motech luggage rack and side racks, Givi E-22 side cases, RKA 36L rack bag, Motorwerk side stand foot, Motowerk highway peg set-up, SW-Motech wide foot pegs, SW-Motech GPS shelf, decalectomy
    Apr 2017
    9
    I just got a 6 sigma jet kit after cutting 3× 1" hole in each side along with k&n filter. I put the 1.15 jets on both inner carbs and the 1.125 on outer carbs. Put two shims on each needle valve and removed covers on bottom of each carb. And turned them out 2 turns. Wow what a difference you can appreciate.
    WERA689 likes this.
    Apr 2017
    9
    Here is the link where I bought mine. Make sure to send email and tell them what mods where done and at what altitude you will be riding above sea level. I live in Indiana so told them 950ft. Above sea
    level...https://www.amazon.com/gp/aw/ya/ref=...310255-8653053
