has anyone fitted dyna 2000 on a zr-7 ?
This is a discussion on has anyone fitted dyna 2000 on a zr-7 ? within the ZR-7 Performance Upgrades forums, part of the Kawasaki ZR-7 category; can anyone advise me on what model dyna 2000 will fit on to my 2003 zr-7 ? would i need to use a kz750 or ...
Results 1 to 6 of 6
Like Tree2Likes
  • 2 Post By shakennstirred
Thread: has anyone fitted dyna 2000 on a zr-7 ?
    Newbie mattblackb9's Avatar
    Sep 2016
    can anyone advise me on what model dyna 2000 will fit on to my 2003 zr-7 ? would i need to use a kz750 or a gpz750 or should i go for another model? do not bother replying if you are just going to tell me it can not be done people said that about fitting 36 mm mikuni flatsliders but runs loads better with them on.
    1,433
    488 times
    Curious, what exactly are you looking at changing by using it? Just the ignition advancement curve? That can be done with a simple advance unit (2, 4,or adjustable) for way less than the $400 or so...
    Sep 2016
    The bike is highly modified with 36mm flatsliders, r6 swing arm ,new one off single seat and sub frame,rearsets,modified top yolk, clip ons,petrol tank lifted up with most of electrics fitted underneath it,i did have a lithium battery under tank between frame tubes but some mice chewed wiring and caused it to blow a hole in side of battery i was lucky not to blow bike up so have just mounted the old one back on a bracket off the bottom yolk behind headlight,new lithium in post, acerbis motocross headlight with high level mudgaurd similar to ducati hypermotad style,the list of one off mods is endless on this bike.I have just stripped it down again ready to have engine rebored to 810cc gas flowed and valves n top end reworked to a new design so this is why i want to up grade the ignition,this bike is a snarling beast that i use on the street but also want to put down drag strip next year.I have been workin on this bike 9years
    1,433
    488 times
    Sounds like you've done a lot of work getting the flatside carbs and pod filters (I assume?) dialed in. Kudos. Upping it to the 810cc will help gain some speed also, But the question still stands. Why the Dyna tuner? NO2 to be added? (BTW, we'd be interested in a pic or two when the bike was "together" wit the mods to see what all ya did)
    Rising Star lpscruggs's Avatar
    Cheney, Kansas
    497
    67 times
    I've used Dyna coils in the past on both my KZ & GPZ 750's and was happy with their products but my bikes were only modded with jetting kits and exhaust (Kerker). And frankly I bought them as simple replacements through Dennis Kirk back in the day. Neither had anything like the K-TRIC system on the ZR7S. Both of my ZRX's have the same system and work flawlessly. I'd say unless you have ignition issues go with stock parts, good used are almost always available on ebay. As far as you're installation of the flat slides kudo's to you, folks said the same thing to me as far as installing Lectron carb on my Yamaha TZ750 back in the day. Please keep us informed as to what you do and what success on this mod if you go forward.
    99' ZR7 Blue
    01' ZR7S Red
    05' ZRX1200R Green
    Nottingham(UK)
    1,190
    244 times
    Quote Originally Posted by mattblackb9 View Post
    Better off asking Dynatek I'd have thought
    I'm running their coils on my ZR7 and bike feels good on them, allied with an ignition advancer and Brisk racing plugs.
    You can really feel the difference with that setup.
    Obo and MagicMexican like this.
    Kawasaki ZR7
