master cylinder upgrade - Page 4
This is a discussion on master cylinder upgrade within the ZR-7 Performance Upgrades forums, part of the Kawasaki ZR-7 category; Anyway back on topic I have found out that Yamaha R1 master cylinders are also 14mm so will be looking at those also. lots on ...
Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 63
Like Tree9Likes
Thread: master cylinder upgrade
  1. #46
    Nottingham(UK)
    1,203
    250 times
    lots on ebay here in the uk.
    Kawasaki ZR7
  2. #47
    8,462
    1493 times
    If that r1 model is correct, it's very good and a step up from the others
  3. #48
    Nottingham(UK)
    1,203
    250 times
    Its the early model R1's before the radial brakes etc.
    friend has one and confirmed its 14mm
    Kawasaki ZR7
  5. #49
    8,462
    1493 times
    The newer one would be better, the brembo marked one, but what the heck. Try what you have, and upgrade if needed.
  6. #50
    Nottingham(UK)
    1,203
    250 times
    the newer ones on the R1 are 16mm and 19mm though
    first snow of the winter here, so now the rock slats is going down, bike is now in hibernation till next year
    Kawasaki ZR7
  7. #51
    1,486
    505 times
    BTW, I did adjust my rear brake pedal as described in the manual (provided by our friendly Canadian contributor Obo) last night, after "winterizing" the bike incase the the riding season's done. (3oz. of stabilizer + 100:1 mixture of 2 stroke oil, clean and wax, chain lube, decrease tire pressure with wood under front tire on center stand, install battery tender pigtail on battery) I ended up taking out approx. 5/16" of travel, and I'll see how well that "feels" when/if weather permits this season. (high about 30degrees with snow flurries YUK!)
    shakennstirred likes this.
  8. #52
    Nottingham(UK)
    1,203
    250 times
    Well I have just bought a R1 master cylinder off ebay. Cost me £40($60).
    It was minus the lever, so have also ordered some levers the same as I have now
    Kawasaki ZR7
  9. #53
    4,348
    882 times
    I've got to ask, why the 2 stroke oil?
  10. #54
    1,486
    505 times
    It puts a very, very slight coat of oil inside the gas tank, the cylinders, etc., and it'll prevent the Viton (rubber) needles from drying out, and prevents sticking needle and seat, should the carbs ever go dry from sitting and/or draining for storage.
  11. #55
    2,199
    180 times
    yup its as old as "fogging" with lots of different types of oil typicly with trans fluid
    fogging is typicly pouring in said fluid down the aircleaner/carbs till the engine dies at idle..makeing for a VERY good coating of the internals for LONG term storage
  12. #56
    Nottingham(UK)
    1,203
    250 times
    R1 Master cylinder came today, so very fast postage from them.
    Looks in good condition, didn't need to order the levers, as the aftermarket ones I have fit.
    Oh well have a spare set now.
    test fitted this lever I had and it fitted perfect
    Kawasaki ZR7
  13. #57
    4,348
    882 times
    Are you going to tear it down to inspect or rebuild it or just swap and see how it feels?
  14. #58
    Nottingham(UK)
    1,203
    250 times
    Think I'll put some fluid in to see if any dirt in it. but it looks clean enough.
    I will then just put it on and see
    Kawasaki ZR7
  15. #59
    Site Elder lpscruggs's Avatar
    Cheney, Kansas
    530
    73 times
    First try HH compound brake pads, and Teflon cored braided stainless steel covered brake lines. Also bleed you're brakes and get totally new fluid that is contaminate free and go from there. I have changed front brake master cylinder switches for increased "power" too with good results.
    99' ZR7 Blue
    01' ZR7S Red
    05' ZRX1200R Green
  16. #60
    Nottingham(UK)
    1,203
    250 times
    I have already done those, this is the next on the list
    Kawasaki ZR7
zr7 nissin
