master cylinder upgrade - Page 2
This is a discussion on master cylinder upgrade within the ZR-7 Performance Upgrades forums, part of the Kawasaki ZR-7 category; braided stainless lines does indeed help considerably on the friont..the rear on the other paw was virtualy unchanged in feel......
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 63
Like Tree9Likes
Thread: master cylinder upgrade
    2,199
    180 times
  2. #17
    1,688
    567 times
    So, in your view it was a waste of time/money except for maybe the look Shortlife?
  3. #18
    Nottingham(UK)
    1,247
    268 times
    the rear is fine on mine, I could lock it if I like
    Kawasaki ZR7
    2,199
    180 times
    i wouldnt say a waste..braided stainless is NEVER a waste..its more durable and will outlast its rubber counterparts and its less likely to fail internaly..j
    ust on the rear of these bikes with the stock MC dont expect it to improve things...mind you after youve gotten a MC id bet money that braided makes a huge difference
    sure i can lock mine up...but no better or worse that i could with the rubber on there
    DaddyFlip likes this.
  6. #20
    1,688
    567 times
    Thanks for the input Shortlife. I'll have to look at my maintenance book for the bike and see when I last flushed the rear brake fluid, and if it's due, I'll probably go ahead and replace with a new S.S. Galfer line (FK003D256R I believe?) when I do it. Shakey, I can skid the rear, it just takes a bit more pressure and travel than I'd prefer "ideally".
  7. #21
    2,199
    180 times
    part# unknown...i hit up a local hyd line shop and had mine made up in mins for about 20 per line
    im with you on the "able" to lock and agree its far too much travel and ZERO real feedback..my xl600r has more feedback ...drum brake
  8. #22
    4,545
    917 times
    Sorry, but through this whole thread when you've said you wanted more pressure on the rear brake all I can think of is bolt a block of wood onto the top of your brake pedal.
  9. #23
    8,557
    1519 times
    Obo, seriously your right. Many times a missed adjusted pedal is the real issue
  10. #24
    4,545
    917 times
    Yes, section 10-5 of the user manual explains how to adjust the rear brake pedal position. That may or may not help with the rear brake feel though.
    The key word here is "feel."
  11. #25
    2,199
    180 times
    mine "looks" miss adjusted but so does my shifter..they have both been tweeked and retweeked for my riding position..i had originaly found my big feet to be resting heavily on them and i was dragging the rear brake
  12. #26
    1,688
    567 times
    Hey Obo, I lost my service manual (PDF) when my old PC crapped out. I don't remember seeing any adjustments for pedal travel "off hand", and of course the owners manual claims that there's none, as it's "automatic" for lining wear. Have a link, or post I can refer to? (either to re-download the service manual, and/or just the rear brake adjustment section you were referring to?) Thanks friend, if you can.
  13. #27
    Nottingham(UK)
    1,247
    268 times
    Yeah there is an adjuster on the bottom of the rod that pushes the piston
    carryall likes this.
    Kawasaki ZR7
  14. #28
    1,688
    567 times
    THANK YOU Shakey. I'll check that out. You guys are the best.
    shakennstirred and DaddyFlip like this.
  15. #29
    4,545
    917 times
    ZR-7 and ZR-7S Maintenance Manual Backup | jadz
  16. #30
    1,688
    567 times
    Thanks buddy...I just saw, and then marked it in "my favorites" from your other helpful reply in the thread "Buying a ZR7S". BTW, I saw some snow flurries here today, so I sent them in your direction friend...that new snow-blower ready "for action"? LOL
zr7 nissin
