Fork spring help
This is a discussion on Fork spring help within the ZR-7 Performance Upgrades forums, part of the Kawasaki ZR-7 category; So this might be a dumb question, but I need the answer. I bought some Race Tech springs. They are longer then the stock springs. ...
Newbie
Fork spring help
So this might be a dumb question, but I need the answer. I bought some Race Tech springs. They are longer then the stock springs. I double checked the part number and it appears to be correct. Do I use the stock spacer or cut the spacer that came with the new springs shorter? Is the longer spring for the increased spring rate? Do I need the total length of the stock spring and spacer to equal the length of the Race Tech spring and spacer? Any advise would be greatly appreciated.
03-18-12 12:13 PM
The directions that came with the new springs should tell you how big of a spacer to use. I know Sonic and Progressive springs both ship with these sort of directions.
Newbie
I couldn't find the directions in the box, but did find some info online. Thanks
I know its kinda old but, where did you find the info at, as ive looked into those springs also.
2010 kawasaki ninja 250r
fork spring help
ninja 250 fork spring rate
ninja 250r 2010 fork springs
ninja 650 cut spacers so that spring and spacer are the same length as stock oe
racetech spring denver
