ZR7 Front Sprocket
This is a discussion on ZR7 Front Sprocket within the ZR-7 Performance Upgrades forums, part of the Kawasaki ZR-7 category; My 2000 ZR-7 has 15 tooth front sprocket. Can a 17 tooth go in its place? Thanks...
Results 1 to 15 of 18
    Newbie atvgolfnut's Avatar
    Jan 2010
    GEORGIA
    11
    ZR7 Front Sprocket
    Super Moderators GUMP's Avatar
    Apr 2002
    Lynchburg, VA
    52
    3,263
    Thumbs up Moved...
    Hey ATV... I moved your post from the Daily Ride... I thought you might get a bit more feedback here. I hope you found it alright.
    As for your question... You CAN go to a 17 tooth front sprocket. Many folks on the board have done that. It WILL require a little modification of the sprocket cover. Nothing major. I will try to find a thread to point you to...
    A quick search found the following... (Thanks Martin!)
    In case you haven't seen this, http://www.zr-7.com/fsprocket.htm , it shows all the details.
    Blurple 2002 ZR-7S -- ZR7OA Member#272
    USS Sturgeon (SSN-637) - 1982-1986
    It is a sentiment that submariners of all navies shared. We had long enjoyed a reputation as nonconformists who hated the monotony of fleet service. We disdained the pomp and circumstance of sideboys, buglers, and holystoned teak quarterdecks. We embraced the hardships of life in a steel tube and the go-it-alone missions that submarines were designed to do. We were a fighting elite, and we knew it.
    snifins.mysite.com
    Jan 2010
    GEORGIA
    11
    Thanks Gump!
    Next question. How much does this drop the RPM at highway speeds and how much does it hurt take off. I am not a hot rodder. Just want to lower RPM (HAVE A SIXTH GEAR) when running highway speed.
    1,019
    try useing this...quite usefull for considering mods to sprockets
    Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
    Johnny Blue Lightnin' JonF's Avatar
    Mar 2002
    Severna Park MD
    11,887
    28 times
    The people here that have gone to a 17t front sprocket have not complained about power issues. The ZR makes decent torque. IIRC the stock front is a 16t so someone must have changed yours. Going from a 15 to a 17 is a huge difference. You may notice it on acceleration. Stock rear is 38t.
    Jan 2010
    GEORGIA
    11
    Thanks, and how do i get to the performance mods page? cant find it. NEVER MIND!!!!!!!!!
    Newbie rustysterling's Avatar
    Apr 2012
    Dallas, GA
    4
    Will the ZR7 hold a 18t front sprocket?
    1,019
    Quote Originally Posted by rustysterling View Post
    i highly doubt it..you need to mod a bit just to keep the 17 from carving out the case and cover....an 18......umm i would guess you would likely have to perminantly lose the cover and remove its mounting holes ...really going bigger just means removing more meat off the case
    Rising Star Hugo Delgadillo's Avatar
    Apr 2004
    Mulberry, FL, USA
    59
    336
    18T won't fit and it is really too much of a drop. Figure roughly about 300 rpm drop in fith gear for every tooth you add in front. Loss of accel is not very noticeable unless your are racing your neighbor at every stop light. Hopefully you are not one of those.
    Apr 2012
    Dallas, GA
    4
    I rode the ZR7 to work this morning. First time since a 17t and new rear tire (Pirelli Diablo).
    Wow, what a difference! I do lots of highway miles, and the new ratio works so much better.
    Thanks for the forum and help, guys.
    Newbie OldBiker's Avatar
    Aug 2012
    Paducah KY.
    10
    Just wondering if the 17t front sprocket changes the hiway buzz. My vibration seems to lessen at higher rpm.. thanks
    Supreme Being zr7_interloper's Avatar
    Aug 2011
    NYC Metropolitan area
    1,518
    41 times
    I think it is quite common in most 4-cylinder bikes. There is vibration at a certain point in the rpm range.
    My zr-7s has the vibration at around 5000 rpm (70 mph). Once you past that point (or below that point), the bike is relatively smooth.
    Sort of counter intuitive--you'd think that as the rpm rises, so would the vibration. Not in this case.
    Aug 2012
    Paducah KY.
    10
    Has anyone figured out how to stop the windshield vibration? Mine rattles pretty hard when slowing down. I am a new zr7s owner, please be patient...
    1,019
    Quote Originally Posted by OldBiker View Post
    remove it?....some well placed bits of rubber washers have workd..som ppl have braced it with aluminum
    Silver Member Serpentine's Avatar
    Sep 2002
    Tampa,Fl
    58
    4,796
    Quote Originally Posted by zr7_interloper View Post
    That's true for something that's out of balance but here we're talking about harmonics.
    Can't slow down, the Langoliers will get me
2000 kawasaki zr7 size of sprocket
2001 zr7s gearing
front sprocket zr7s stock
how to increase horsepower for 2000 kawasaki zr750
how to remove the cover to the front sprocket on a kawasaki zr7s
kawasaki zr7s gearing
kawasaki zr7s sprockets
sprocket size for 2000 zr-7
stock gearing 2000 kawasaki zr7
stock sprockets for kawasaki 2000 zr7
what is the stock sprocket 2000 kawasaki zr750
zr-7 sprockets
zr-7s front sprocket
zr-7s front sprocket torque
zr7 18 teeth
