jetting database - Page 4
jetting database
This is a discussion on jetting database within the ZR-7 Performance Upgrades forums, part of the Kawasaki ZR-7 category; Originally Posted by KawRider00 hey guys its prolly stupid to do it but i took the stock muffler off and i really like the sound ...
Page 4 of 4 FirstFirst 1234
Results 46 to 58 of 58
  1. #46
    Rising Star tnichols's Avatar
    Apr 2006
    Pennsylvania
    179
    Quote Originally Posted by KawRider00 View Post
    hey guys its prolly stupid to do it but i took the stock muffler off and i really like the sound and was thinking of keeping it off what jetting would u guys recommend doing
    I would probably just leave the jetting the way it is... That way when you get tired of all that noise and put the mufflers back on, you will not have to rejet again
    But if you are already hard of hearing and you do decide to leave them off, you probably will want to rich-en up low speed circuit with 38 pilot jets. The main jet is already pretty big. But check out the thread and you will get an idea of what you need to do. Good luck.
    2001 Kawasaki ZR-7S (ZR750H)
    - Current mileage is 20,800 miles
    - Custom Mustang Seat
    - GIVI bags E36/E45/E36
    - Garmin 2610 GPS
    - Harley Back Rest
    - Shinko 009 RAVEN RADIAL Tires
    - Stock Air Cleaner, Exhaust, Gearing
    - Zero Gravity Windscreen
    - @ 08,750 miles replaced rear BT020 tire
    - @ 17,500 miles replaced front BT020 tire
    - @ 20,000 miles replaced rear brakes
    - Pennsylvania, USA
    - My Web Site: http://tomstoys.50webs.com/
  2. #47
    Johnny Blue Lightnin'
    JonF's Avatar
    Mar 2002
    Felton, DE
    53
    12,097
    115 times
    No muffler or aftermarket? If just an aftermarket muffler very little change if any is needed.You could probably get by with just setting the idle mixture screws to about 2 turns out from lightly seated. If you change the air intake side that will require jetting.
  3. #48
    Newbie Atom 3's Avatar
    Oct 2012
    Exhaust: Scorpion
    Air filter: Conical's
    Mains: 110
    Pilots: 38
    Needles: 1 Washer
    Elevation: Sea level
  5. #49
    Rising Star custer's Avatar
    May 2013
    lacey, wa
    31
    231
    Exhaust- equal length 4-1 w 1 1/2 " baffle
    modified airbox- pods
    K&N filter- emgo
    Pilot Jet not nessecary
    Main Jet 136 secondary main
    Shim / or clip 2nd needle clip podition
    Jet kit- plead the 5th
    elevation (if you know it) near sea level
    Dave
  6. #50
    Nottingham(UK)
    1,190
    244 times
    Exhaust= Yoshi RS-3 can
    modified airbox= yes
    K&N filter= yes
    Pilot Jet= standard jet 1.3/4 turns out
    Main Jet= 100(DJ)
    Shim / or clip= 2shims & 3rd clip
    Jet ket= Dynojet
    elevation = 107.552 feet
    with all the problems I had fitting the kit(what happened is in another thread)
    im pleased to say the bikes running great, its pulling harder between 3-6k and is running a lot smoother and snappier
  7. #51
    May 2013
    lacey, wa
    31
    231
    did anybody else drill their slides?
    Dave
  8. #52
    Nottingham(UK)
    1,190
    244 times
    anyone have a copy of the airbox mod you get in the ivans jet kit?
    I would like to see where the holes have to be drilled
    thanks
    Kawasaki ZR7
  9. #53
    Nottingham(UK)
    1,190
    244 times
    I have put the holes on the back of the airbox where it faces the battery box, its covered from rain more that if you put them on the top and the battery box etc stops it coming off the wheel.
    since doing it the main thing I have noticed is the hesitation just off tick over seems to have gone
    Kawasaki ZR7
  10. #54
    1,433
    488 times
    airbox cover holes.jpghere it is...again
  11. #55
    4,295
    870 times
    Holey!
    Did you also remove the foam intake baffle in the intake lid? Not that it will likely make much difference with those additional holes.
  12. #56
    Nottingham(UK)
    1,190
    244 times
    mine didn't have the foam intake baffle but did have the white plastic, I removed that as that give a bigger opening.
    I didn't want to do the holes on the top like the pic, so had a look and it seems like the best place was at the back where it faces the battery box.
    its covered by the intake that's over the battery and the mudguard n battery box from anything coming off the rear wheel, mine has the undertray also
    next time I take the seat off i'll get a pic.
    not my airbox, just a pic to give you an idea where the holes are
    Kawasaki ZR7
  13. #57
    4,295
    870 times
    If you drilled under the lip where the white baffle is would that allow extra airflow while giving some water protection or would the neck where it bends cause the same restriction as stock? I'm wondering where the restriction is, at the opening or part way to the air box itself.
  14. #58
    Nottingham(UK)
    1,190
    244 times
    that wouldn't help, as your still using the same little intakes that feed into the airbox
    Kawasaki ZR7
2000 kawasaki xz 750 jetting for 5000 ft
2000 kawasaki zr-7 mainjet size open carbs
2002 zrx1200r factory high altitude carb adjustments
87 kawasaki ninja 750 flat spot when accelerating
air box mod kawasaki zl900
drz 400 jetting database
drz jetting database
holeshot jet kit instruction
kawasaki slow jet 38/35 carb specs
what is the standard main jet size for a klr 650
