Fork oil replacement, fork stuck collapsed..
This is a discussion on Fork oil replacement, fork stuck collapsed.. within the ZR-7 Maintenance forums, part of the Kawasaki ZR-7 category; So I'm changing my fork oil and installing preload spacers, after compressing the fork / cycling it to get the oil out its catching when ...
Results 1 to 4 of 4
    Up-And Comer 99GrandTouring's Avatar
    Mar 2003
    West Virginia
    36
    99
    So I'm changing my fork oil and installing preload spacers, after compressing the fork / cycling it to get the oil out its catching when collapsed and doesn't want to re expand... any ideas or am I going to have to disassemble?
    Thanks
    Supreme Being DaddyFlip's Avatar
    Sep 2013
    SEARK
    47
    2,096
    404 times
    See my post in your other thread. Happened to me years ago. Be patient and next time you get it free, don't compress it all the way again!
    2001 ZR-7s (ZR750H1).....R.... "Ol' Red"
    1995 FXDWG Dyna Wide Glide "Grunt Pig"
    4,547
    917 times
    Give the lower tube a light tap downward on the lower lip where the seals are with a rubber mallet while holding the upper tube in your hand. It will come free. It doesn't take much force. Alternatively you can give is some good pulls and it will come free. The key is to use less force and work your way up until it releases vs reefing on it from the beginning and not to scratch the upper tube.
    1,693
    567 times
    Had me bummed out once too. It'll come free.
