Oil Analysis: Texaco Havoline 20W-50 (API SL)
This is a discussion on Oil Analysis: Texaco Havoline 20W-50 (API SL) within the ZR-7 Maintenance forums, part of the Kawasaki ZR-7 category; Lab: Schaeffer's Specialized Lubricants Engine: 739cc air/oil-cooled four-stroke four-cylinder motorcycle engine with combined transmission and wet clutch. Miles on engine: 27,154 Miles on oil sample: ...
Results 1 to 2 of 2
    Rising Star richard612's Avatar
    Apr 2002
    San Bernardino, CA
    438
    Miles on oil sample: 3000
    Miles on oil filter: 3000
    Oil: Texaco Havoline 20W-50 (Current API SL formulation).
    Make-up oil added: Approx 5% of total crankcase volume.
    Operating conditions: 65F to 100F, mixed high and low speed/RPM, no short trips, moderate idle time
    Engine condition/tune: Good overall. Mild knock at startup. Factory jetting, pilot screws 3 turns out (overrich idle). Modified exhaust and airbox, stock air filter element.
    Results from previous 3k mile analysis of Delvac 1300 Super 15W-40 are in "()"
    Results from previous 3k mile analysis of Rotella T Synthetic 5W-40 are in "[]"
    Copper: 1ppm [2ppm] (2ppm)
    Iron: 12ppm [10ppm] (16ppm)
    Chromium: 0ppm [0ppm] (0ppm)
    Aluminum: 4ppm [3ppm] (6ppm)
    Lead: 0ppm [1ppm] (1ppm)
    Moly: 3ppm [3ppm] (71ppm)
    Phosphorus: 832ppm [976ppm] (1769ppm)
    Zinc: 1005ppm [972ppm] (1852ppm)
    Magnesium: 48ppm [220ppm] (757ppm)
    Calcium: 2339ppm [2950ppm] (4071ppm)
    Anti-freeze: 0% [0%] (0%)
    Fuel Dilution: none [none] (none)
    H2O: 0% [0%] (0%)
    Silicon: 3ppm [2ppm] (3ppm)
    Viscosity: 15.34cSt@100C [13.94cSt@100C] (13.67cSt@100C)
    Mfr viscosity spec: 19.0cSt@100C [14.6cSt@100C] (15.5cSt@100C)
    Oxidation: 1% [0%] (9%)
    Nitration: 0% [0%] (2%)
    TBN: Not tested.
    Soot: Not tested.
    What is all this crap? See here: http://theoildrop.server101.com/whatisoilanalysis.htm
    My thoughts:
    1. Considering how ****-poor this stuff made my tranny shift, the numbers look good.
    2. There really is no reason to think that a synthetic is going to add substantially to the engine's life. Between my one test with synthetic, my two with conventionals, and Berto's test with a synthetic, the wear-metal numbers with the synthetics are just not that much better. Synthetics are great oils, but the conventional oils seem to do just fine. Many have noted a shift-quality improvement, and that alone might justify the added cost of a synth.
    3. Of particular note is the viscosity loss of this oil. This test result is the only one of the four where the oil fell out of grade. 15.34cSt is ballpark with the other oils, so it's not like this stuff sheared down to salad-oil levels. But it's still interesting to note that the other oils were all xxW-40. This was a 20W-50 that sheared back to a 40-weight. A cheap conventional 10W-40 might shear down so much that protection suffers and the wear-metal numbers could begin to rise.
    Unless I get my hands on another special oil analysis kit deal, this will be the last of my tests for a while. I'm out of kits.
    Apr 2002
    San Bernardino, CA
    438
    One more thing... If somebody asks me what oil they should use in their ZR-7, my answer will be:
    Oil is good. Use some.
20w-50 oil with sl api
20w-50 sl api
20w50 oil with api sl rating
20w50 sl-api
havoline 20w 50 specs
havoline 20w50
havoline 20w50 specs
havoline 20w50 synthetic motor oil
havoline motorcycle oil
havoline oil analysis
