Pilot Screw O-rings
Pilot Screw O-rings
This is a discussion on Pilot Screw O-rings within the ZR-7 Maintenance forums, part of the Kawasaki ZR-7 category; Hello all, New member, new (old) ZR7 owner. I bought a 2000 naked ZR7 from forum member anticsfl. It had been sitting for over 6 ...
Results 1 to 5 of 5
    Newbie Inshan's Avatar
    May 2011
    5
    Unhappy Pilot Screw O-rings
    Hello all,
    New member, new (old) ZR7 owner. I bought a 2000 naked ZR7 from forum member anticsfl. It had been sitting for over 6 months, so needed the carbs cleaned. I have done it once before with success on my EX500 (half the # of carbs though).
    However, when I did it this time on the ZR7, I managed to lose 3 of the pilot screw o-rings
    I did the Pine-sol method and it worked well, but when I was rinsing out the carb bank, I forgot that the o-rings had remained in the holes... and I flushed them out real good, lol.
    So now I need 3 o-rings. From the EX500 forum I found out that this part number is the right one for the EX500: 92055-1002
    Anyone know if the ZR7 uses the same part number, or where to get them. I see the listings for the entire crew, spring, washer, o-ring set, but all I need is o-rings.
    Thanks,
    Inshan
    Johnny Blue Lightnin'
    JonF's Avatar
    Mar 2002
    Felton, DE
    53
    12,100
    115 times
    www.bikebandit.com or www.ronayers.com and I think there is a some kind of carburetor parts .com too. bike bandit or ron ayers wil get you the right part for sure.
    May 2011
    5
    Thanks JonF for the suggestions, will check them out...
    Site Elder graeme.medley's Avatar
    Nov 2004
    Sauble Beach, Ontario
    60
    986
    Looking at the parts microfiche, the closest big K list is the whole pilot needle assembly - part # 16014-1092
    If you still have one of the 'O-rings available, try a motor parts type store, or even eBay, for the same size.
    As it's part of the fuel system you will need them made of nitrile rubber.
    ZR7OA member #759
    1999 ZR-7 New Candy Wine
    Ignition advancer, Hugger, Braided steel brake lines, Progressive fork springs, FUEL end can, Fenda-extenda, Scotoiler Mk7 with HCR, K&N Filter, LED Rear Lights, Fuel gauge mod, GIVI rack plate and boxes:
    May 2011
    5
    Thanks Graeme. I have one, so will try local shops first with it.
ex500 pilot screw part number
ex500 pilot screw spring
kawasaki 92055-1002
o ring screw
pilot screw 16014
screw o-ring
screw with o ring
valkyrie pilot screw o ring
what does the gs500 pilot screw do? is the 0 ring required?
yamaha carburetor pilot screw o-rings
