Is anyone seeing issues w/ Carbs from Ethanol Gas??
This is a discussion on Is anyone seeing issues w/ Carbs from Ethanol Gas?? within the ZR-7 Maintenance forums, part of the Kawasaki ZR-7 category; Back in the Spring I had a major tune up at the local bike shop. Bike ran great after wards and rode it 2 or ...
Results 1 to 10 of 10
    Boy Scout 03'7S-Ben's Avatar
    May 2003
    West Union, South Carolina. USA
    46
    1,342
    8 times
    Back in the Spring I had a major tune up at the local bike shop. Bike ran great after wards and rode it 2 or 3 times right after that. Unfortunatel she sat in the garage until a couple of weeks ago. I took a Sunday drive from Upstate South Carolina to Chattanooga, TN. for some BBQ During the ride I had an "Idle" issue especially at lights, stop signs and just slowing down. When I would be in 1st Gear with clutch compressed the Idle speed would really jump up. If I would release the cluth just before it would engage(so I would not stall at light) the idle speed would go down.
    My 1st thought was do I have an issue with my Throttle Cable?
    2nd thought was since the bike had sat most of the summer "Evil Ethanol Gas" there is supposedly a 10% mixture with gas in my area. I know that can vary depending how long the gas may be sitting in the gasstation tanks.
    Went down to the local bike shop and they were very helpful by listening to my issue and remember my bike from this past Spring" Appareantly they don't see too many ZR-7S's. The shop mgr. thinks that my issue is the dirty Carbs / Jets from Ethanol gas. His recomendation was to take the tank off and get into each Carb (one at a time) and check the jets and clean them. He said to be careful and make sure you mark where the throttle cable is for each one. I've also heard about putting Sea Foam in the tank and running it through the Carbs as well.
    Any help on this issue. What do you all think the issue is? I will be taking my time and cleaning the Carbs myself. I think I read somwhere that a 1/4" tube is the size to drain the gas from the Carbs? Does this sound correct?
    Thanks in advance for all suggestions and oppions on Ethanol Gas for now on I will be buying Ethanol "Free" gas from a local station I would rather pay .20 more and not have the issues. Also if I can't then I will be mixing Star*Tron Fueln Treatment in my tank. www.startron.com
    Ben
    West Union, S.C.
    03' ZR-7S
    ZR7OA Member #603
    Johnny Blue Lightnin'
    JonF's Avatar
    Mar 2002
    Felton, DE
    53
    12,113
    116 times
    I think you're right Ben. Before you go into the carbs try some Seafoam. It really works. I used it on my four wheeler after it sat for a few months and a few days later it was as good as new. A friend of mine is a small engine mechanic and he says the manufacturers recommend 89 octane or better gas because it causes less carb issues. It must have better additive packages. If you can get ethanol free go for it but if the bike is going to sit the best bet is to use fuel stabilizer and drain the carbs.
    Sep 2003
    Ottawa Canada
    2,109
    I ran 10% ethanol for 53,000 miles without a single carb problem ... but then I did drain the carbs and used fuel stabilizer when stored for the winter. Pay the extra if you want, but the fuel isnt' the issue - it maintenance.
    May 2003
    46
    1,342
    8 times
    I'll definitely give the Sea Foam a try. It's worth a shot and to hopefully save the time from getting into the engine. Here are some links that I've checked out for Sea Foam
    http://video.google.com/videoplay?do...0865726229173#
    http://www.seafoamsales.com/products.html
    It's amazing what all Sea Foam is used for. I'll be picking up a bottle in the next day and report back.
    Thanks, Jon
    Ben
    West Union, S.C.
    03' ZR-7S
    ZR7OA Member #603
    May 2003
    46
    1,342
    8 times
    Went to my local NAPA Parts Dealer and bought 2 Cans of the Sea Foam for $6.35 each I guess thats a good price? By the way wrote an e-mail to Sea Foam and below is the response / recommendation on what I should do. Will be following the process below this weekend and report the results back to you guys.
    Ben
    Just add Sea Foam to the fuel and in your case I would add 2 ounces of Sea Foam per gallon of fuel. After adding the Sea Foam run the bike for about 10 minutes making sure the Sea Foam and fuel mixture gets into the carbs. The let sit for a few days, in that time Sea Foam will dissolve any gum of varnish in your carb. Then after some soak time start the bike and take if for a ride. As the bike runs you will notice improved idle quality. Sea Foam is a pure petroleum blend and will dissolve any petroleum based deposits cleaning out your carb. Sea Foam will not affect of harm any component in the fuel system because Sea Foam contains no chemical additives.
    Jim Davis
    Sea Foam Sales Co.
    Technical Service Manager
    ASE Certified Automotive Technician
    Ben
    West Union, S.C.
    03' ZR-7S
    ZR7OA Member #603
    Super Moderators
    GUMP's Avatar
    Apr 2002
    Lynchburg, VA
    56
    3,324
    22 times
    Thumbs up Sea Foam
    Ben, it was an ugly-ish winter up hear this past year (2009 - 10) and my poor ZR-7S sat outside, un-run, for more time than I care to admit.
    When it finally dried up and I began to ride again (more) I found I had symptoms similar to those you describe. For the record, most of the gas in this area is 10% ethanol also. So, I tried Sea Foam. Used 1/2 a can per tank for two tanks. Seems to have helped. Has been running well since....
    Good luck with yours.... I know it is irritating when you can finally get out for a ride and the bike doesn't want to play fair.....
    Take Care friend...
    Blurple 2002 ZR-7S (Sold August 2015) -- ZR7OA Member#272
    Tahitian Blue 2014 Honda CBR-650F
    USS Sturgeon (SSN-637) - 1982-1986
    May 2003
    46
    1,342
    8 times
    Gump,
    Thanx for the testimonial (if that's a word) I'm definitely looking forward to trying the "Foam" out. Boy if it works it will be the best thing since sliced bread
    Ben
    West Union, S.C.
    03' ZR-7S
    ZR7OA Member #603
    Rising Star locojim's Avatar
    Mar 2008
    Streator Illinois
    276
    I use stabil and start mine monthly through the winter...
    As far as not riding for a couple weeks,I've found a good back road and a couple WOT bursts through most of the gears cures any idle problems fairly quickly...
    JonF's Avatar
    Mar 2002
    Felton, DE
    53
    12,113
    116 times
    Quote Originally Posted by JonF View Post
    I was I a hurry when I typed this. What I meant to say was that they (the small engine manufacturers) say the 89 octane gas seems to cause less carb varnish issues after an engine has been sitting unused for a period of time compared to an engine that has been unused for a period of time with 87 octane in it.
    I'm not sure I believe it either but thats what they say. I spend the extra few cents for my four wheeler, mower, generator, and snowblower gas now just in case.
    May 2003
    46
    1,342
    8 times
    I always use te 93 octane in the bike. The bike is babied more then anything in the garage. For now on the bike, lawnmower & all small engines in the garage will get Ethanol Free gas.
    Don't worry Jon I knew what u meant.
    Ben
    West Union, S.C.
    03' ZR-7S
    ZR7OA Member #603
carbs and ethanol
clean atv carburetor after ethanol gas been in long time
ethanol free gas for 4 wheelers
ethanol fuel and 4 wheelers
ethanol in four wheeler
ethanol in four wheelers
kawasaki zr 7 stalls when slowing down
klr ethanol
should i use ethanol free gas in my 4 wheeler
will seafoam dissolve gum from ethanol
