tried to Jump start
tried to Jump start
This is a discussion on tried to Jump start within the ZR-7 Maintenance forums, part of the Kawasaki ZR-7 category; So battery just died after a 45 minute ride, had to pop start it to get home. wouldnt start again after leaving it running. today ...
Results 1 to 9 of 9
    Up-And Comer anticsfl's Avatar
    Jul 2009
    28
    119
    tried to Jump start
    So battery just died after a 45 minute ride, had to pop start it to get home. wouldnt start again after leaving it running. today i threw some jumper cables on it and alas nothing happened. im curious is the battery just toast or maybe the rectifier is done? any help would be great- rick
    2000 ZR-7 Candy Lightning blue 24110
    1+/-1, Johnf Shifter mod, Pilot powers F/R airbox mod, HIDs
    1996 Yamaha FZR 600 Stripped and ratted out
    1994 CBR f2
    2007 KX450f
    2005 RM250
    2003 RM250
    2004 YZ125
    1999 YZ125
    1999 YZ80
    1997 XR80
    1984 DR100
    1995 Z50
    Rising Star Cracker Jack's Avatar
    Nov 2005
    462
    Presumably you're speaking of the ZR-7. With some more info, some of the real experts here can help. First, we know it's a 10 year old motorcycle. Is it a 10 year old battery? Do you have a voltmeter?
    Jack
    Cracker Jack
    74 Norton
    02 ZG1000
    03 ZR-7s (hers)
    03 ZR-7s (mine)
    83 GS750 (sold)
    04 GS500F (sold)
    97 ZL600 (sold)
    75 Norton Interstate (sold)
    71 Norton Roadster (sold)
    Jul 2009
    28
    119
    well it is a 00zr7 probably stock battery and i do have a multi meter but no real knowledge of how to check something like the battery
    1994 CBR f2
    2007 KX450f
    2005 RM250
    2003 RM250
    2004 YZ125
    1999 YZ125
    1999 YZ80
    1997 XR80
    1984 DR100
    1995 Z50
    Site Elder graeme.medley's Avatar
    Nov 2004
    Sauble Beach, Ontario
    60
    986
    Sounds like the battery.
    Charge the batery and leave overnight. It should still have a 12v charge. If it hasn't its history.
    With the engine running put the multimeter across the battery teminals and measure the voltage. It should be about 11.5v raising to 14v by 3000rpm.
    Stop the engine and the battery voltage should drop to about 12.5v and stay at that value.
    With a toasted battery, if the the bike will run once you've started it then the alternator and rectifier are supplying 12 to 14 volts to the circuit. Even though the battery isn't taking a charge it will be acting as a voltage stabiliser, and preventing the bike from frying the rest of its electrical system.
    ZR7OA member #759
    1999 ZR-7 New Candy Wine
    Ignition advancer, Hugger, Braided steel brake lines, Progressive fork springs, FUEL end can, Fenda-extenda, Scotoiler Mk7 with HCR, K&N Filter, LED Rear Lights, Fuel gauge mod, GIVI rack plate and boxes:
    Jul 2009
    28
    119
    At this point it wont start at all, with jumper cables or a starter box. so i guess ill try a new battery then whatever doesnt work next
    1994 CBR f2
    2007 KX450f
    2005 RM250
    2003 RM250
    2004 YZ125
    1999 YZ125
    1999 YZ80
    1997 XR80
    1984 DR100
    1995 Z50
    Jul 2009
    28
    119
    ended up just being the battery and the main fuse. put a new bike master battery ind it started right up,
    1994 CBR f2
    2007 KX450f
    2005 RM250
    2003 RM250
    2004 YZ125
    1999 YZ125
    1999 YZ80
    1997 XR80
    1984 DR100
    1995 Z50
    Newbie simon5264's Avatar
    Aug 2010
    4
    Check the earth strap on right hand engine case mine came loose
    Up-And Comer FASTACID's Avatar
    Nov 2008
    Miami Fl.
    59
    When my battery failed to start the bike I Push started it for about a month before replaceing the battery.
    I couldn't afford one right away. Daily rider
    Beach Cruiser Street Bruiser
    00 zr7
    muzzy S/S header, aluminium can
    Jett stage 1
    17TH front spr.
    Reshaped seat,desert camo. cloth cover
    LED tail/brake lights
    LUKS Racing halogen
    90/110 watt headlight bulb
    120/70frt.
    180/55rr.
    K/n filter
    progresive fork kit
    no gauges, bent handlebars and levers
    sometimes i miss the gas gauge
    Up-And Comer junayd's Avatar
    Mar 2008
    77
    Quote Originally Posted by FASTACID View Post
    My kind of biker!!
    Rain sleet of hail i'm riding broke or not i've got to get to work and the zr-7 is a crash it pick it up and ride it away kinda bike - ( not a savage crash mind you)
can you push start a 1996 yamaha fzr 600
fzr 600 battery problems jump start
