The oil catch bottle and drain
This is a discussion on The oil catch bottle and drain within the ZR-7 Maintenance forums, part of the Kawasaki ZR-7 category; Well, saw lots of posts on this but did'nt see any pix so here's how I did it: Pic1 Tools required Pic2 Right side view ...
Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Up-And Comer TerryE's Avatar
    Jun 2004
    Howell,MI USA
    41
    The oil catch bottle and drain w/Pics
    Pic1 Tools required
    Pic3 w/seat and side cover removed
    Jun 2004
    Howell,MI USA
    41
    oil catch bottle continued Part 2
    continuing on: Remove screws from cover and set cover out of the way.
    Jun 2004
    Howell,MI USA
    41
    oil catch bottle Part3
    continuing on:
    Jun 2004
    Howell,MI USA
    41
    oil catch bottle Part4
    continuing on:
    Jun 2004
    Howell,MI USA
    41
    oil catch bottle Part 5
    continuing on:
    Note: Tighten Step cover bolts (green circled) to 18ft-lbs 25N-m per manual
    Brake cylinders bolts :if loosened or removed in error (red circled) to 17ft-lbs 23N-m per manual.
    Jun 2004
    Howell,MI USA
    41
    oil catch bottle Part 6
    finishing up, reinstall side cover, tail cover and seat.
    Up-And Comer funk1980's Avatar
    Dec 2009
    Netherlands
    38
    Thanks! Pictures say a thousand words
    nml
    nml is offline
    Newbie nml's Avatar
    Sep 2008
    14
    Nice one.
    Maybe this could become a sticky?
    Site Elder Doug Hyde's Avatar
    Mar 2004
    Delaware
    923
    Nice write-up. BTW, I've always been able to wrestle the bottle out without having to remove that lower cover. I think a good mod would be to either relocate the bottle or extend the lower tubing and route it so it would be easier to access. I rarely check mine because in almost 33K miles I've never had any oil to speak of in the bottle -- I guess I'm too easy on the engine.
    2003 ZR-7S
    ZR7OA No. 984
    AMA, MSTA, Retreads Int'l.
    Mods/Farkles: Givi E-21 side cases, ZG S-T windscreen, Throttlemeister w/ custom-made fingerwheel, Garmin 60-CSx GPS, BMW Sport Grips, Kisan Tailblazers, fuel guage mod, Fenda Extenda, 1" spot mirrors, Formotion clock, Fiamm horn, Datel voltmeter, Progressive 11-1145 fork springs, digital thermometer, EGR/PAIR/whatever you wanna call it system removed, Fuel end can.
    News, product reviews & "stuff" on Tilted Horizons!
    Up-And Comer Dunewar's Avatar
    Oct 2007
    93
    I've never needed to undo the lower rightside panel to drain te bottle. I can just pull it out, and I push it in just on top of the lower panel. I drain it every month, there's allways something to come out, sometimes quit a lot of oil comes out. I guess i'm not soo soft on the engine...
    Sep 2003
    Ottawa Canada
    2,109
    I've never removed the covers or even moved the bottle much when draining it. A semi-long set of needle nose pliers going in along the swing arm to move the spring clip then pull the plug at the bottom of the bottle. Drain. Replug and reclip.
    Dec 2009
    Netherlands
    38
    Thanks a lot for opening this topic! I'm a beginner when it comes to maintenance and didn't even know there was such a thing as a drain bottle . This kind of info is great for people like me.
    So when preparing my bike for the better weather today, I drained the bottle. Without removing the panel by the way.
    Here's the harvest:
    Rising Star Stormsmack's Avatar
    Jul 2006
    San Antonio,TX
    254
    idk, maybe I'm not as green as some of u guys. I just pulled the plug on mine and routed another hose over to the chain. my own oiler!
    ZR7OA member #1473
    03 zr7s
    carbon fiber muzzy's
    ivan's jet kit
    egr-ectomy
    coerce low bars
    mirror extenders
    custom fender eliminator
    flush mount turn signals
    ZG Double bubble smoked wind screen
    Kawasaki Green is the fastest color
    Site Elder NightViper19's Avatar
    Jun 2008
    Reynoldsburg, OH
    652
    Quote Originally Posted by Stormsmack View Post
    Lol, Ive heard of this. Does it actually work the way its supposed to? I just lube the chain every 500 miles, since its got a centerstand, its wicked easy.
    2001 ZR-7S - too many mods for the signature to handle, apparently.
    Reverse Trike - Built from scratch
    DIY Mods for your ZR
    Sep 2003
    Ottawa Canada
    2,109
    Look at the picture above. Would you run dirty black oil on your chain? I would think that a) there's very little oil actually getting on the chain so you still have to lube and clean it, and b) you'd be adding more dirt than oil which would shorten chain life. I'm on my 3rd set of chain and sprockets. Expensive enough as is without something shortening the lifespan.
17ft-lbs=25n-m
2002 kawasaki zr7s oil leak at air breather
bottom of the bottle oil drain
build a motor oil bottle drain
diy oil catch for bike
draining oil from oil bottles
kawasaki drain breather oil
motorcycle breather pipe catch bottle/?
oil bottle drain rack
oil bottle drainer rack
oil bottle draining system rack
oil catch bottle
oil catch bottle on kawasaki stx-12f
oil catch bottles
oil drain bottle
