Need help with Backfiring and rough idle
This is a discussion on Need help with Backfiring and rough idle within the ZR-7 Maintenance forums, part of the Kawasaki ZR-7 category; Hello all ZR mechanics, I hope this thread does not get thrown out by the moderators but I just bought a KLR 650 (still have ...
    Silver Member wilk's Avatar
    Jul 2002
    Montreal, Canada
    206
    I hope this thread does not get thrown out by the moderators but I just bought a KLR 650 (still have my ZR-7s) and I am having trouble.
    The motor backfires during heavy deceleration/engine braking and at idle, it is not steady when adjusted to around 1400 rpm, it misses and fluctuates +/- 200 to 300 rpm.
    Any ideas will be much appreciated!
    Kevin Williams
    Montreal, Canada
    Mods:
    Mirror Extenders
    Corbin Seat
    Givi V46 top case w/ Givi rack
    Mar 2004
    Delaware
    1,035
    36 times
    I'm no expert, but does the KLR have an idle mixture screw you can get to? If so, I'd adjust it to get the highest stable idle, then set the idle speed and take it for a test ride. If that didn't work, I'd make sure I didn't have an overly-lean condition from an air leak. It might help others to know if your carb/airbox/pipe are stock.
    2015 Versys 650 ABS
    (Former owner 2003 ZR-7S)
    Mods/Farkles: Puig "Touring" windscreen, Givi hand guards, BMW Sport Grips, Omni-Cruise throttle lock, Motowerk mirror extenders, SW-Motech gas cap mount tankbag, Denali Mini Soundbomb horn, Mag-Knight tank pad, SW-Motech luggage rack and side racks, Givi E-22 side cases, RKA 36L rack bag, Motorwerk side stand foot, Motowerk highway peg set-up, SW-Motech wide foot pegs, SW-Motech GPS shelf, decalectomy
    West Coast Moderator
    Martin64's Avatar
    Yuma, Az
    53
    12,996
    101 times
    Was it parked for a while (months)?
01 ducati 900ie back firing idle rough
klr 650 idle adjustment
klr 650 idle mixture screw adjustment
klr 650 idle speed
klr 650 rough idle
klr 650 wont idle
klr rough idle
klr strange idle
klr650 rough idle
zr7 rough idle
