Changing spark plugs
This is a discussion on Changing spark plugs within the ZR-7 Maintenance forums, part of the Kawasaki ZR-7 category; I'm curious, how often do you change the spark plugs on your ZR-7s. THe service manual says to check them every 3000 miles, but doesn't ...
Results 1 to 9 of 9
    Rising Star sf_frank's Avatar
    Jan 2005
    Belmont, CA
    371
    I'm curious, how often do you change the spark plugs on your ZR-7s. THe service manual says to check them every 3000 miles, but doesn't say when to change them.
    "I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own." - No.6; The Prisoner
    http://www.xsrider.com
    IBA #14938
    ZR7OA Member#: 1462
    2003 ZR-7S
    Byron Bay Australia
    72
    5,609
    Hi sf frank,
    gg changes his plugs at say 20,000kms (12,000miles) for no other reason than habit, the old plugs are kept under the seat for a rainy day.
    Lady gg's car has "extended life" plugs which are changed at 50,000kms
    gg@bb, ava good day
    Supreme Being Bronto's Avatar
    Mar 2003
    Alamo, CA
    1,659
    With the plugs only lightly tightened. They come loose easy, around 3000 miles. At same time it's an opportunity to clean em up. Emery cloth sanding the electrodes. Brush clean up using carb cleaner. Before replacing, small amount of diaelectric grease on the connector and thin coating inside the boot.
    I replace around the 7 k miles. Clean at 2500 and 5000 miles.
    Found some Ebay sellers have best price on ngk plugs. If use the irdium plugs, can go longer before replacing them. Only clean with carb cleaner, no sanding.
    Alan - Green GSX1300R - Former Blurple Zr7sS rider
    Silver Member javasutra's Avatar
    Feb 2003
    Nicholasville KY, USA
    48
    1,941
    I would replace the stock Densos with NGK plugs at the earliest convenience.
    '02 ZR-7S Blurple - Traded for a:
    '05 DL-650 Red - Totalled by a Mercury Replaced with:
    '06 DL-650 SilverBlue
    Johnny Blue Lightnin'
    JonF's Avatar
    Mar 2002
    Felton, DE
    53
    12,113
    116 times
    Going from memory I changed mine somewhere around 12,000 miles.
    Up-And Comer Stpetezr7's Avatar
    Dec 2004
    St Petersburg, FL, USA
    97
    Plugs
    I replaced mine at like 14,000. Should have done it earlier, around 12k. Bike ran smoother, better throttle response, did it in conjunction with my valve adjustment. Just make sure to use a torque wrench, a cheap investment to prevent an expensive mistake! Even the cheap beam type is accurate, just not as easy to use.
    Jan 2005
    Belmont, CA
    371
    Thanks for the your comments. I think I change my spark plugs when I get to 12K miles. I'm at about 9500 miles right now.
    Frank
    IBA #14938
    ZR7OA Member#: 1462
    2003 ZR-7S
    Supreme Being chiller's Avatar
    Sep 2004
    At the moment: Mississauga, ON Canada
    1,131
    did mine at 12k then didn't do it until last thursday, so they lasted 40k and didn't look too worn either compared to the new ones...the color on them was just right as well..., just changed it for the sake of having new plugs for the new riding season...
    "Group rides are simple, we all go together, we all come home together"
    ZR7OA # 1230
    Site Elder HiG4s's Avatar
    Jan 2003
    Saint Johns, FL
    60
    843
    I did mine at 10k, didn't really need it yet.
    2003 KTM 250SX
    2007 Yamaha Royal Star Venture
does motorcycle spark plugs need to be greased
how to change kawasaki zr-7 spark plugs
how to change spark plugs in a 2013 ducati streetfighter
motorcycle manual says change plugs at 12000 miles plugs look like new
whic spark plugs for 2003 zr7
zr-7 spark plug
zr7 spark plug grease
