Sticky/hard shifting repair with pics. - Page 7
This is a discussion on Sticky/hard shifting repair with pics. within the ZR-7 Maintenance forums, part of the Kawasaki ZR-7 category; maybe it's time to admit defeat and take it to a professional .... lol...
Page 7 of 7 FirstFirst ... 34567
Results 91 to 102 of 102
  1. #91
    Supreme Being zr7_interloper's Avatar
    Aug 2011
    NYC Metropolitan area
    2,283
    146 times
  2. #92
    4,330
    878 times
    Quote Originally Posted by zr7_interloper View Post
    Now now now, it's not that bad yet. We still haven't suggested a mild explosive agent.
  3. #93
    Rising Star SoccerKyCoach's Avatar
    Oct 2007
    Louisville, KY
    244
    Weather was in the 60's on Sunday so I went over to my buddy's garage and tried to muscle the panel off again. Blasted EVERYTHING with the PB Blaster... panel still won't budge. Hooked up the shifter and decided to ride it up and down the street again to rotate the shifter shaft and see if it would help break the panel loose... and all that PB Blaster has the thing shifting like a dream. Smooth as butter and shifter is returning to "neutral" after both up- and down-shifts. That's all well and good as long as it's shifting like it did on Sunday... but I still wanna get that damn panel off to do some more preventative maintenance so I don't start having troubles while I'm out on a ride someday.
  5. #94
    4,330
    878 times
    Well if you have tried all the muscle and lube you can, I concurr with Interloper. Take it to a professional. Only other option is to cut / break it and then replace it with a new/used cover.
  6. #95
    2,199
    180 times
    you need to find an edge to slide in on...find a corner and try slowly driving a utilityknife blade into the gasket area..yeah your going to break some blades..but you will get in there..dont be shy about useing a hammer to drive them in either just dont hit them crazy hard
  7. #96
    Nottingham(UK)
    1,198
    249 times
    when I got my bike 3 weeks ago
    one of the first jobs I did was clean and grease the gear linkage
    lovely n smooth now.
    also I moved the lever up a little to make it easier to get my boot under it
  8. #97
    Newbie cooks's Avatar
    Jan 2017
    10
    I was gonna do this to help with my bike today but the bolt (130) in the attached image is rounded.
    It's very hard to get it, not much space for vice grips or pipe wrench etc. Any ideas?
  9. #98
    Mar 2004
    Delaware
    1,029
    35 times
    I have a set of these which have saved me a few times: Sears.com
    Quote Originally Posted by cooks View Post
    2015 Versys 650 ABS
    (Former owner 2003 ZR-7S)
    Mods/Farkles: Puig "Touring" windscreen, Givi hand guards, BMW Sport Grips, Omni-Cruise throttle lock, Motowerk mirror extenders, SW-Motech gas cap mount tankbag, Denali Mini Soundbomb horn, Mag-Knight tank pad, SW-Motech luggage rack and side racks, Givi E-22 side cases, Motorwerk side stand foot, decalectomy
  10. #99
    4,330
    878 times
    You might have to do the center punch / chisel option.
  11. #100
    4,330
    878 times
  12. #101
    Up-And Comer makenzie71's Avatar
    Dec 2016
    116
    Go to harbor freight and get a small pair of needle nose locking pliers (vice grips)...and lock them way the hell down on the bolt.
  13. #102
    Jan 2017
    10
    I tried the punch etc.
    Took it to a friend who is a mechanic, he was able to get a pair of small vice grips onto it, More tools, strength and experience prevaled.
    The cover was hard to get off too, sprayed wd40 anywhere it might be stuck. After a while and a bit of knocking with abit of wood from the back end it came out.
    Feels like a new bike now :-). Thanks for the thread OP.
2003 yamaha fjr 1300 shifting shaft noise?
fjr1300 hard to shift
how to fix a sticky foot shifter on a motorcycle
king quad shift hard
klr 650 hard shifting
my 01 650 vstar shifts hard
my 650 vstar shifts hard
troubleshooting hard shifting on a 300 king quad the foot shifter
why does my 2002 king quad 300 shift stiff
zr7 gear change issues
