BRAKE PAD REPLACE
This is a discussion on BRAKE PAD REPLACE within the ZR-7 Maintenance forums, part of the Kawasaki ZR-7 category; I,ve just turned over 16k miles on by bike and was wandering about how long the brake pads should last. I don't ride really hard, ...
Results 1 to 5 of 5
    Up-And Comer jp red's Avatar
    Nov 2003
    oakdale, ca
    64
    126
    BRAKE PAD REPLACE
    I,ve just turned over 16k miles on by bike and was wandering about how long the brake pads should last. I don't ride really hard, yet i don'd baby it ether. Also, how do i check the pads? I did notice that the fluid was just a bit lower than when it was new. Thanks for the help.
    MotoMacGyver emrah's Avatar
    Chaska, MN
    38
    2,546
    Did you look to see how far downb they were worn?
    Emrah
    "I haven't yet done everything, but by the time I'm finished, I won't have missed much. If I auger in tomorrow, it won't be with a frown on my face. I've had a ball."
    - Gen. Chuck Yeager
    www.grandamerican.com
    www.derhaag.com
    '00 Blue ZR-7 (Sold and I miss it dearly...)
    '05 Blue Suzuki SV-650S (Most overrated bike on the planet)
    '04 Grey Ninja 250 WHOOO-HOOOO!
    Gold Member/Community Dad Berto's Avatar
    Feb 2002
    Big Shanty, Ga. USA
    55
    5,742
    jp,
    really depends on how the bike was ridden. I replaced the rear pads on my '01 model @ 13k miles, probably could have gone 20k but had a big trip plan. 1mm is the service limit, measured from the metal backplate the pad is attached to of the brake - to determine thickness, need to lay down and look up at them. Get your flashlight out.
    The front still had 40% left @ 23k miles, I'm not a heavy brake user so your mileage may vary.
    Berto
    ZR7OA Member#: 229
    Nov 2003
    oakdale, ca
    64
    126
    Thanks Emrah and Berto. After Emrah's post i felt like duh, what a dumb question. went home, looked up at the pads with a light approx 3mm to 4mm left. Lots of miles still to go on them. Thanks guys
    Up-And Comer Sportbilly's Avatar
    Sep 2002
    Omaha, Nebraska
    80
    And here's a tip:
    Don't top up the fluid before checking on the status of your pads, else when you replace the little buggers you might have too much fluid. If they're close to replacing, do it, then check fluid again.
    Then again you could just take the opportunity to flush and bleed 'em...
    Sportbilly, Professional Slave, Amateur Alcoholic
    '89 GS500E (retd.), '00 ZR-7 (resurrected!), '04 Yamaha V-Star 1100
    "Oh, bother" said Pooh, slapping another magazine into his AK-47.
