zr-7s replacement front indicators
This is a discussion on zr-7s replacement front indicators within the ZR-7 Accessories forums, part of the Kawasaki ZR-7 category; Hi guys, I found my front right indicator dangling this morning. Either the wife or kid must have brushed against it or something. Anyway, the ...
Results 1 to 10 of 10
  • 1 Post By Obo
Thread: zr-7s replacement front indicators
    Up-And Comer anilv's Avatar
    Jul 2015
    115
    Hi guys,
    Anyway, the stock one is too expensive and there doesn't seem to be any on eb@y or the 'for sale' part of this forum so I'm planning to go aftermarket, at least until I can source an original one for the right price... yeah I'm cheap.
    Most of the ones I see now are the LED types, I don't really like these as they seem to be lacking in brightness. I would be interested to hear feedback from those who are using them.
    Are there any other bikes which share the similar mount, ie matches the recess in the fairing? Zr-7s are not too common.
    Anil
    4,446
    898 times
    Is the old one fixable? Some epoxy or something? That's an inexpensive route.
    As for going LED you may find your lights will blink faster. You'll either have to live with the fast blink rate, install load resistors or an adjustable flasher unit.
    Kawasaki Front Turn Signal EX500 EX EX-500 ZR750 ZR 750 ZR-750 ZR-7S Flasher | eBay
    if this is right, the ex500's should have a similar indicator. I'm sure it's not the only one. Likely some of the older gpz models too.
    Mar 2004
    Delaware
    1,035
    36 times
    You may know this, but the hard rubber mount piece is separate from the rest of the signal stalk and can be replaced; both of mine eventually failed from age/sun.
    2015 Versys 650 ABS
    (Former owner 2003 ZR-7S)
    Mods/Farkles: Puig "Touring" windscreen, Givi hand guards, BMW Sport Grips, Omni-Cruise throttle lock, Motowerk mirror extenders, SW-Motech gas cap mount tankbag, Denali Mini Soundbomb horn, Mag-Knight tank pad, SW-Motech luggage rack and side racks, Givi E-22 side cases, RKA 36L rack bag, Motorwerk side stand foot, Motowerk highway peg set-up, SW-Motech wide foot pegs, SW-Motech GPS shelf, decalectomy
    4,446
    898 times
    Cialis for rubber lol. Fix it up as good as new. Age and sun be darned.
    Doug Hyde likes this.
    Jul 2015
    115
    Thanks Doug,
    I truly did not realize this! Will definitely check this out.
    Anil
    Jul 2015
    115
    Obo,
    Original are out there but they're kinda pricey so I figured on going aftermarket.. but still not decided as I'm not too sure that the brightness is good.
    I've been trying to eyeball other bikes with LED indicators but its shocking how many bikers don't use them!!
    Anil
    1,520
    513 times
    Or measure the recess and find a pair of small surface mount ones that will 3M tape in place.
    Site Elder SuprHtr's Avatar
    May 2005
    Huntsville, AL
    671
    I had to replace the rubber parts on both of my fronts this year. Check Ronayers.com. $9.66 each before shipping. I can't imagine any aftermarket options being cheaper... YMMV.
    "The squeeky wheel gets the tack weld!"
    2003 ZR-7S
    1995 GPz 1100
    Tolerant Wife
    Site Elder lpscruggs's Avatar
    Cheney, Kansas
    562
    81 times
    I had to replace mine too, twice ! Kansas summer sun can be brutal ! When I got the replacement rubber parts I ordered 3 extra sets.
    99' ZR7 Blue
    01' ZR7S Red
    05' ZRX1200R Green
    Jul 2015
    115
    OK.. this is an update on the turn signals..
    1. I called Kawa and they said they had the part.. MYR16 (around USD4). Yayy.
    2. Go the part and surprise, its plastic, not rubber? WTH? Anyway cost was ok so I bought it. This was on Friday.
    3. On Saturday, I tried to fit it... bummer It wont fit! Checking the online parts fiche I can see that the part I have (23051-1248) needs a different lamp head... Seems that up to 2002 Kawa used a plastic spacer and the turn-signal lamp had a bolt which passed thru this and bolted inside the fairing. On the 2003 models the lamp bolted to the rubber thing which was in turn screwed to the fairing.!
    pic of wrong part below
    4. So now I need the correct part, 23051-1207. I believe I can modify the plastic bit and make it fit but I will need to extend the bolt by using a stand-off nut and making some spacers.. bikes has been 'van gogh'ed' for the moment.
    Anil
