2000 ZR-7 Lowering Links
This is a discussion on 2000 ZR-7 Lowering Links within the ZR-7 Accessories forums, part of the Kawasaki ZR-7 category; well,i said they would work. my sister is 5/2 and they did the trick for her. what no credit for this ?...
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
    Silver Member buster's Avatar
    May 2004
    pinellas park Fl.
    57
    1,678
    It is better to remain silent and be thought of as a fool,then to open your mouth and remove all doubt. Abraham Lincoln.
  3. #17
    1,019
    isnt that a bit too low to be rolling thru the twistys?..a lil bit of lean and your draggin and lifiting the weight off the tires....
  4. #18
    May 2004
    pinellas park Fl.
    57
    1,678
    Quote Originally Posted by sh0rtlife View Post
    i had to remove the centerstand and feet must ALWAYS be on top of the pegs when cornering but as long as you are not to agressive you are ok.
    1,019
    i get hit in the helmet by tall daisys when im out carving sooo yeah
  6. #20
    Rising Star Wado750's Avatar
    Feb 2005
    Perth, Australia
    467
    Do these lowering links have enough adjustment to raise the back end as well?
    Neil
    Yamaha FZ8S
  7. #21
    Newbie joeycraig's Avatar
    6
    i have lowering links for 2002
    zr70s
  8. #22
    Silver Member Dr. Dirt's Avatar
    Aug 2002
    PA
    425
    As to the original question of lowering the motorcycle for less than $50, have you tried the little things you can do for free? Reduce tire pressure by 2 psi. Slide the forks up until they almost touch the handlebars. Trim the seat foam 1/2 or 3/4 inch (12 to 20 mm). Reduce the pre-load of the rear shock to its minimum. None of these mods will get you very much closer to the ground but if you are [U]almost [U] where you want to be collectivelly they help a little bit.
    Quote Originally Posted by buster View Post
    i had to remove the centerstand and feet must ALWAYS be on top of the pegs when cornering.
    What about the side stand? Once upon a time when I thought I wanted my 2000 ZR-7 to be lower I had the stock links modified and then had to shorten the side stand because I was worried when I had to park with the left side of the bike even slightly up hill.
    Dr. Rench
    2000 Blue (SOLD)
    Rifle Nightflight Fairing
    Progressive Front Fork Springs
    SS Brake Lines
    Carb Screws 2.5 turns out
    DIY Dremel Rear Fender Eliminator
    Front Fender Extender
    Turn Signal Beeper
    170/60x17 Rear Tire
    17 Tooth Front Sprocket
    MotoSpecialties Mirror Extenders
    *Masters Degree in ZR-7 Tool Production*
2000 kawasaki zr7 rear suspension sdjustments
how far out can a lowering link be adjusted
kawasaki zr7 2000 lower links
kawasaki zr7s lowering link
lower kawasaki zr 7
lowered zr 7
lowered zr7
lowering link for 2000 kawasaki zr7
more hp out of my 2000 zr7?
pods on my 2000 zr7
zr 7s lowering link
zr7 for dirt
zr7 lowering
zr7 lowering links
zzr1200 lowering links
Tags for this Thread
