had to replace my guage cluster lights, so i went LED... - Page 7
This is a discussion on had to replace my guage cluster lights, so i went LED... within the ZR-7 Accessories forums, part of the Kawasaki ZR-7 category; Originally Posted by zr7_interloper I prefer to have very dim lights on the gauges when riding at night. You and your ZR stealth bomber......
Page 7 of 9 FirstFirst ... 3456789 LastLast
Results 91 to 105 of 133
Like Tree7Likes
Thread: had to replace my guage cluster lights, so i went LED...
  1. #91
    4,295
    871 times
    Quote Originally Posted by zr7_interloper View Post
  2. #92
    Supreme Being zr7_interloper's Avatar
    Aug 2011
    NYC Metropolitan area
    2,283
    146 times
    Lights are over-rated
  3. #93
    Up-And Comer Leweykinz's Avatar
    Jul 2013
    Carmarthenshire, UK
    28
    90
    8 times
    Been reading this post as 3 of my gauge bulbs have blown. And because I am a cheapskate have decided to go with shaken and got me the value range:
    10mm Xenon White (x10) for £2.78 - 10 x LED Side Light / Interior / Number plate Bulbs T10 W5W 501 Xenon White | eBay
    5mm Xenon White (x10) for £2.88 - 10 X Car T5 73 74 286 Dashboard LED White Light Bulb Lamp 12V Replacement | eBay
    Total Cost - £5.66
    Will post pics when finished!
  5. #94
    Nottingham(UK)
    1,190
    244 times
    Quote Originally Posted by Leweykinz View Post
    Total Cost - £5.66
    I ended up going for the green leds and the clocks look great
  6. #95
    Jul 2013
    Carmarthenshire, UK
    28
    90
    8 times
    Bugger - bit late for that :P
    Oh well as long as they work OK! (was a little worried about them saying there 5w each?)
  7. #96
    Jul 2013
    Carmarthenshire, UK
    28
    90
    8 times
    Right got them all in, and working fine so far! Not amazing coverage for the speedo/tacho (should of probably got the higher flooded LED's). This was taken in the garage during day time, so excuse visibility.
  8. #97
    4,295
    871 times
    As long as you can see them in the dark you're good
    What type of hard bags do you have? (I see the Givi like key)
  9. #98
    Jul 2013
    Carmarthenshire, UK
    28
    90
    8 times
    Ummmm newbie so quite possibly will get this wrong. But I think I got the Givi monorack and Givi V46 Monokey System?
  10. #99
    Up-And Comer welshbrummie74's Avatar
    Feb 2012
    Birmingham, UK
    98
    21 times
    That lloks pretty good. my rev counter bulbs have all gone. haven't read this thread, but is it pretty easy to replace them with those bulbs you linked to? Do they just slot in? and i take it there is no issue with power being different for the led bulbs to stock originals? I'm crap with electrics and know nothing. Almost gave myself a stomach ulcer trying to sort out new wiring for my rear indicators when I got my Givi rack!
  11. #100
    Feb 2012
    Birmingham, UK
    98
    21 times
    Also, do you need both the 10mm and 5mm bulbs? Excuse my ignorance :-)
  12. #101
    Jul 2013
    Carmarthenshire, UK
    28
    90
    8 times
    As far as i know there is no issue with slightly higher bulb wattage... The bulbs just slot right in once you get the backing off, no further mods needed...
    May of done this the long winded way, but here is what I did:
    - You need to take the main headlight glass cover off first
    - Un-clip all of the wiring connections (don't worry about mixing up as clips are all different sizes)
    - Loosen and remove the speedo cable (which runs through to gauge lower case)
    - Unscrew the 3 gauge mount bolts (it detaches in one piece making it easier to get to bulbs)
    - Go around each of the bulbs one by one and replace with LED's (I believe it was 6 x 5mm and 3x 10mm for the ZR7 2001 naked)
    Hope this some what helps, I really know nothing about cars/bikes and didn't take me too long to figure out...
    Good Luck!
  13. #102
    Nottingham(UK)
    1,190
    244 times
    yeah very easy to do and worthwhile.
    i'll try and get a pic of mine with green led's in at the weekend.
    I have put green led's in everything but the high beam light and the oil pressure light which I used white led's
  14. #103
    Feb 2012
    Birmingham, UK
    98
    21 times
    Thanks for the run through Leery. And shaken, that would be great if you could get a pic up. I've ordered the white LEDs but not s great outlay, so on to greenies if they look good!
  15. #104
    Nottingham(UK)
    1,190
    244 times
    Quote Originally Posted by welshbrummie74 View Post
    i'll try tonight when its darker
  16. #105
    Nottingham(UK)
    1,190
    244 times
    about as good as I can do with my phone in the dark
2002 zrx 1200r gauge lites
changing globe 250 kawasaki ninja replaceing
dash light bulb for kawasaki ex500
how to replace dash lights in an 81 honda nighthawk
kawasaki 2004 zrx 1200 replacing intrument lights
kawasaki speedometer light bulb zrx
ninja 500 gauge lights
zrx 1200 gauge lights
zrx 1200 instrment lights
zrx instrument lights
