New (13-15) ZX6R Shock on 06 Z750s? - Page 2
This is a discussion on New (13-15) ZX6R Shock on 06 Z750s? within the Z1K/Z750 Performance Upgrades forums, part of the Kawasaki Z1000, Ninja 1000, Z800, Z750 & Z-750S category; Awesome thanks for all the help! Rerouting a wire or two is no problem for me. As for the dogbones, I kinda figured that it ...
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
    Newbie jtbask11's Avatar
    Sep 2016
    9
    As for the dogbones, I kinda figured that it wouldn't make a difference but it was only a couple bucks more for this shock. This shock is also clean so it'll look nice after a polish.
    I'll update when I get it installed. Can't decide if I should do this before powdercoating the swingarm or doing it all in one go.
    Also, it took me til now to realize you were talking about the regulator/rectifier, not sure what I was thinking before.
    Rotating or even relocating the r/r shouldn't be difficult.
  2. #17
    Sep 2016
    9
    Got the shock installed. Has probably a half to a quarter of a millimeter of clearance between it and the cross member. There was some little metal pin sticking out of the member that I didn't remove, it's hitting the shock a bit but it shouldn't be a problem.
    Installation was easy, the hardest part was getting the bike up to work on. Ended up using a rope and a $30,000 piece of machinery.
    The bike sits a bit higher, is way firmer, and doesn't hit the member even when bouncing.
    Thanks for all the help. Next step is the 636 front end, but that's gonna take a lot more work, money and time.
    2006 Black Z750s - Two Bros Slip-on - PCV - 2010 ZX6R Shock - Tail Tidy Kit - LED Taillight with Integrated Turn Signals - LED Rear Turn Signal Strips - Puig Frame Sliders - Corbin Gunfighter Seat - Denali Sound Bomb Mini 115db Horn - SpeedoHealer - Chinese Universal Mirrors with Integrated Turn Signals - Black Bolt Kit - Driven D3 Grips - Black Shorty Levers - LED Gear Indicator - Crappy Nylon Water Bottle Holder
  3. #18
    Aug 2012
    Athens, Al
    74
    Wow that's close I love my zx14 shock easy to adjust for added passenger weight and fits like stock maybe 2 inches between it and the cross member. Don't know why no one else has tried it yet. The zx6 front end really isn't that bad to do especially if you know any machinist or live close to a technical school
Tags for this Thread
