upgrade z with engine motor z 1000
This is a discussion on upgrade z with engine motor z 1000 within the Z1K/Z750 Performance Upgrades forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; Hello I m called Regis I am French Bordeaux for people who know. i m turn of you because i would like instal a motor ...
Results 1 to 2 of 2
    Newbie akra's Avatar
    Smile upgrade z750 with engine motor z 1000
    Hello I m called Regis I am French Bordeaux for people who know. i m turn of you because i would like instal a motor of z 1000 2006 on my z 750. In France nobody does this kind of modification.i am turning to you for so know exactly what I needed that when mounted to a complete engine z 1000 on z 750. I would ascend as a breech of zx9r.ais I need absolutly power commander? I must take the ecu the z1000? thank you to you
    Sorry for the spelling I go through a translator
    Up-And Comer MAD-MAX's Avatar
    May 2006
    Greece-Norway
    48
    77
    Quote Originally Posted by akra View Post
    You gonna need a power commander and you can use the 750 ecu as i had done on my Z 1000.CHOOSE A power commander V WITH AUTOTUNE from zx6r 2009 plug it straight at injectors ,give a good af/ratio target map to autotune and enjoy a bike thats faster than a Z1000 due to xtra rpm the 750 ecu gives...
    "orange Z1K"
    STROKER
    13,5/1comp ratio
    zx-9 racing cams +springs
    Full Race spec ported head
    zx-9 flywheel
    zx-10 throttles
    arata full race 4-1
    pc3 usb
    ign module(rev-xtend)
    velocity stacKs +pod filters
    z750 ecu (12700 rev limiter)
    OHLINS Rοad N Track front forks
    320mm wave rotors
    ohlins rear
    ??? rwhp(so far)
    PCV+AUTOTUNE MAPPED!!!
    to be continued...
2012 z1000 engine modification
kawasaki z1000 engine upgrade
upgradez
why is the zx9 faster than the z1000
z1000 porting
zx9r engine info z1k
