Formula for calculating speed with different sprocket sizes.
This is a discussion on Formula for calculating speed with different sprocket sizes. within the Z1K/Z750 Performance Upgrades forums, part of the Kawasaki Z1000, Ninja 1000, Z800, Z750 & Z-750S category; If you want to see how a sprocket change affects your speed vs. RPM the formula is as follows; Speed in MPH=RPMxFSTxTCMM, divided by PGRxGRxRSTx26817. ...
Results 1 to 13 of 13
    dippitydoo
    Guest dippitydoo's Avatar
    RPM=engine RPM
    FST=front sprocket teeth, (15,16 or whatever)
    TCMM=tire circumference in milimeters, (a 190 50 zr17 is about 1975mm)
    PGR=primary gear ratio, (Z1000 2003-2006 is 1.714)
    GR=gear ratio, (What gear your in ratio, Z1000 1st=2.571 2nd=1.941 3rd=1.555 4th=1.333 5th=1.200 6th=1.095, 2003-2006) choose one only.
    RST=rear sprocket teeth
    26817=26817 the number to convert from circunference in mm to MPH.
    So with a 16 tooth front and a 42 tooth rear in 6th gear at 11,000 RPM your speed would be 164 MPH. with a 15 tooth front retaining the 42 rear your top speed in 6th at 11,000 RPM would be 154 MPH.
    I hope this helps.
    Rising Star Firehawk's Avatar
    Oct 2007
    San Diego, CA
    160
    I made an Excel spreadsheet that will do it all for you, just put in the information.
    Let me know if you find anything wrong with it.
    http://www.mediafire.com/?nx3akovdhn0
    2003 Z1000 - black
    Site Elder canuckerstone's Avatar
    Apr 2007
    758
    Cool!
    2005 Black Z1000 - nicely modded
    Supreme Being INTHERED's Avatar
    Sep 2007
    Marriottsville, MD
    1,017
    I have an excel spreadsheet for the speed calulations that may be a bit different then Firehawks if you want I can email it to whoever wants it. I went to the link Firehawk provided but I could'nt download it due to the firewall here. I have attached a jpg that shows my spreadsheet output format. On my spreadsheet you enter in RPM and tire size (you can also change rear ratio but the default is stock 42/16) and the spreadsheet calculates the rest for each gear 1 thru 6 but it will not work on anything except a Z1000 since the transmission ratios are locked.
    INTHERED
    2009 ORANGE/BLACK HD XR1200
    2008 ORANGE/BLACK KTM 990 SUPERDUKE, Akrapovic Slipons
    2008 ORANGE/BLACK HD FXDL, Vance & Hines Slipons, XIEDs, SE Heavy Breather AC
    SOLD! 2003 ORANGE Z1000, Yosh Slipons, PCIII, K&N w/stage 2 airbox
    Supreme Being greencheezeeta's Avatar
    Dec 2006
    1,155
    Or just go to: www.gearcommander.com
    I think thats the way it is spelled. Just pick your bike and make the proper adjustments.
    Sep 2007
    Marriottsville, MD
    1,017
    www.gear what ????????? your link does not work
    Up-And Comer J.U.R.C.A's Avatar
    Sep 2006
    52
    Quote Originally Posted by INTHERED View Post
    http://www.gearingcommander.com/
    Stay tuned
    Sep 2007
    Marriottsville, MD
    1,017
    That link works.
    Now I wish I had'nt of wasted my time making my spreadsheet.
    I really like the section on determining chain length when changing sprockets.
    INTHERED
    Site Elder z1000pwnr's Avatar
    Dec 2007
    500
    That website rocks ty!
    Up-And Comer water's Avatar
    Feb 2010
    Fairfax, CA
    119
    Thumbs up
    Awesomeness!
    Helped me decide on -1/+2 conversion... I was a bit concerned that my cruising rpm would be higher - but it's not that significant... And I get to use the same chain :-D
    Silver Member buster's Avatar
    May 2004
    pinellas park Fl.
    61
    1,727
    15 times
    Why make it so complicated ? All you need is a base point. Let us say 16/42 is 4krpm at 60mph. 42 divided by 16 is 2.625 and 42 divided by 15 is 2.8 2.635 divided by 2.8 is .9375 and .9375 times 60 is 56.25 so lowering one tooth in this case changes 4k at 60mph to 56 mph. Anyone but me understand this ?
    It is better to remain silent and be thought of as a fool,then to open your mouth and remove all doubt. Abraham Lincoln.
    Site Elder ballsdeepracing's Avatar
    Apr 2008
    Beautiful Coeur d'Alene, ID
    690
    am I supposed to do this while I'm riding? it sounds like riding to canada and converting MPH to KPH. My head hurts already
    2005 z1000 Candy Blood Red
    Enough mods to build another bike
    "I want to make this thing fly!"
    dippitydoo
    Yes
    Quote Originally Posted by buster View Post
    Yes but people are to lazy to do any calculations. A real human will use a formula and do it on paper not with a calculator. I think that is one of the reasons we are all f****d.
calculate new speed after adjust spocket
calculating sprocket size vs rpm
formula for sprocket speed
formula of sproket rpm
how sprocket size affects speed and rpm
how to calculate sprocket rpm
how to calculate sprocket speed
how to determine sprocket size
motorcycle sprocket size vs speed
sprocket speed formula
