This is a discussion on ZX10 wheel swap details. within the Z1K/Z750 Performance Upgrades forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; Originally Posted by Expat Below is a photo showing the rotor side spacer and also the ones I used to offset the caliper. You cannot ...
CUSTOM METALLIC BURNT CANDY ORANGE and BLACK 2010 Z1000 :0)
FMF APEX slipon exhaust, CRG Arrows W/ RS CUSTOM barends, Blue CoreMoto SS brake lines, Pazzo Smoke Shorty Levers, Custom LED Intergrated Taillight, XenTec 35W HID's ( 5000K Bulbs ), OES Frame Sliders, Baldwin pillion seat, Keiti Tank Pad, Tech Spec C3 Tank Grips, swing arm spools
Expat.
Black 03 Z1000.
Shortened CF Akrapovic slip ons. K&N filter + air box mod. Powercommander III.
Speedohealer. Twin light conversion. Renthal ultra lows. Bar end mirrors. Tail tidy. Sargent seat.
Renntec grab rail (only fitted when passengers are on!) Shock racing LED mini turn signals.
Throttle quickener. Motovation frame and fork sliders.
Rizoma case sliders. Shorty Pazzo levers. Hyperpro RSC damper. Driven +3 520 chain conversion
06 ZX10R wheels with stock wavy rotors.
Custom stainless steel wheel spacers, footpeg pins, bar dampers and caliper spacers.
06 ZX10R front and rear brakes.
Black HEL lines with Red fittings.
07 Silver ZX6R forks with Race Tech .95 springs.
06 ZX6R shock. 06 ZX6R front fender.
05 GSXR600 Track bike
84 Yamaha RZ350 restoration project....
88 YSR50
00 KTM 200 EXC.
07 Kawasaki KX100
Please make a complete set and sell it! I just got a killer deal on a set of wheels and I got a good axle. I am having trouble finding a reliable source locally. Please let me know.
if i could find someone to sell a set of spacers, i would buy the zx10 rims in a hurry!
Is the '06 ZX10R front rim a direct replacement for an '05-06 636 front rim?
I guess I'll be the test rat this time. I'm going to try the different bearings for using the stock Z axle with the zx10r rear wheel. Talked to a friend that works for "Bearing Distributers" and he thinks it will be just fine(lets hope). I'll let you guys know once I get it put together next week an post some pics.
The hub is narrower on the ZX10 so you will still need new spacers for the axle and also to offset the rear caliper.
Expat.
Black 03 Z1000.
88 YSR50
00 KTM 200 EXC.
07 Kawasaki KX100
I figured out that the stock bearings from the Z1000 front wheel will fit in the 05 zx10r rear wheel perfectly. I already fitted the new bearings in the zx10r front wheel, and have decided to double them up on account of them being narrower. I have access to a machine shop and will make all of the new spacers at one time. I'll post up some pics of it all when I am finished.
How about a whole ZX10 Engine swap? ne one know if it can be done with changing the wiring harnes, and the gauge cluster etc.........
Keep on ridin and ridin hard............Zoooooooom!
Do a search for "Z-king" or maybe "Z-King" for the zx10r engine swap details.
I bought a Z and promised myself I'm going to leave it alone.... these threads aren't helping me keep that promise.
Here are a few pics of my swap. Did the 636 front suspension at the same time, so the bike looks much different to me now. Handles much better too! I think the black wheels give it a more sinister look. I'll take some better pictures in the daylight and post them in the "Post a pic of your ride II" thread.
Rear spacers:
just a thought, but what if you ran a complete zx10 rear end with swingarm, wouldnt that be easier or would the alignment be way off? I am thinking about doing this over the winter but I want the nice fat swingarm too. The zx10 swingarm goes fairly cheap on ebay $50 if you ask me thats a steel. Luckily a family member owns a machine shop so if I start wrestling this project I will be sure to make all extra spacers incase anyone else might want to do the swingarm swap.
the problem with the ZX10 swing is the shock offset is dif than on theZ swing. I am sure it could be done but with some welding to the frame.
