636 Swap complete...my experience
This is a discussion on 636 Swap complete...my experience within the Z1K/Z750 Performance Upgrades forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; Originally Posted by johnnyzx10r Just finished my z 2007 with zx14r wheels , zx14r rotors , and yamaha r1 calipers very nice job, really clean ...
Page 31 of 31 FirstFirst ... 212728293031
Results 451 to 460 of 460
  1. #451
    Supreme Being RS117's Avatar
    Jul 2005
    vermont
    44
    5,032
    Quote Originally Posted by johnnyzx10r View Post
    very nice job, really clean looking
    CUSTOM METALLIC BURNT CANDY ORANGE and BLACK 2010 Z1000 :0)
    FMF APEX slipon exhaust, CRG Arrows W/ RS CUSTOM barends, Blue CoreMoto SS brake lines, Pazzo Smoke Shorty Levers, Custom LED Intergrated Taillight, XenTec 35W HID's ( 5000K Bulbs ), OES Frame Sliders, Baldwin pillion seat, Keiti Tank Pad, Tech Spec C3 Tank Grips, swing arm spools
  3. #452
    Rising Star Shogun's Avatar
    Jul 2006
    Okinawa, Japan
    39
    346
    Hot Damn thats sweet looking!! Did you get your lights (HIDs) squared away?? Man that black on gold is bling schwing right there!!
    2009 Z1000
    All Rizoma->Tail Tidy w/Zero 11 rear signals, Engine Case Covers, Rearsets, Silver Grips, Brake Reserviors ASV Levers, HID's, HEL Braided lines, Arrow Darkline Exhaust, Motivation Frame+Fork Sliders, OEM Seat Cowl+Bellypan, Puig Hugger, 636 Front Forks with Ohlins Springs, Ohlins Rear Shock, DNA Air Filter+DNA Stage 2 lid, PCV, GiPro gear indicator, Rideitmoto Mirrors, Sprint steering damper, Powerbronze Seat.
  4. #453
    Rising Star Antihero's Avatar
    Sep 2009
    LA/IE/OC area
    292
    Quick question. I have done the front end swap and the rear suspension swap but my mechanic said the calipers are not straight. I have 05 zx6 caliper mount on the 05 forks so do I need 10mm spacers?
  5. #454
    Site Elder crowbar's Avatar
    May 2008
    Manchester NY
    705
    The spacers only add distance to accommodate the bigger rotor. Your caliper being off sounds like your calipers are junk.
    New York USA
    R.I.P.
    Gavin "Greencheezeata" Butts
    October 5, 1983 - September 8, 2009
    Need help installing a mod? message me and I can answer any question you may have.
  6. #455
    Newbie scotty595's Avatar
    Dec 2011
    9
    Hey all,
    Have a 2010 Z750 here (2nd Gen) - Looks like I should be good to go for the fork swap however just trying to figure out 1 final detail. Most of the posts here talking about the Z750 wheel not working except with different bearings or machining the wheel - however they seem to be referring to the 1st gen Z750 - which has RWU forks not USD forks. Anyone know if this has changed in the 2nd Gen? So basically will I be able to get forks, axle, spacers, calipers, lines and then run it through the clamps and wheels? or will I need to get new bearings etc for the wheels?
    Any info required let me know!
  7. #456
    Dec 2011
    9
    Looks like I may have found the answer to my own question (Although ebay isn't really a great place for 100% accurate research) - but seems that the 2nd gen Z750 uses a 20mm spindle *Cry*
    Guess I need to fit some different bearings
    http://www.ebay.co.uk/itm/LOOK-KAWAS...-/370343871184
  8. #457
    Rising Star mac11's Avatar
    Jun 2008
    outside chicago
    29
    223
    so if i read this correctly i need a ~2mm caliper spacer to use '10 zx-10 calipers with '04 zx6 forks and '03 z1000 rotors?
  9. #458
    May 2008
    Manchester NY
    705
    Unless 2010 calipers are more shallow, 10mm is what you want. 03-04 636 forks used a 280mm rotor, the Z1000 is a 300mm. So a 10mm spacer is needed to offset the expanding rotor size. Also, not sure if you saw, the 03-04 forks are set from the factory for a much smaller rider and are less ideal than the 05-06. Plus the 05-06 forks run a 300mm rotor, so no spacer is need to offset the calipers.
    New York USA
    R.I.P.
  10. #459
    Jun 2008
    outside chicago
    29
    223
    Quote Originally Posted by crowbar View Post
    I was pulling info from DYNAGREGO. Yes, the 2010 (i think 08+) zx10 caliper mounting lugs are different than zx6 caliper mounting. So it looks like with 03-04 ZX6 FORKS, 08+ zx10 CALIPERS and z1000 DISKS I should need a 2mm caliper mount spacer. Then another 10mm spacer if I want to step up to 320mm disks.
    Quote Originally Posted by dynagrego View Post
    SORRYi've forgotten that you are using 03-04 ZX6 forks.
    These forks because of the 280mm discs have 10mm lower caliper mounts than 05-08 ZX6 and 04-07 ZX10 forks.
    So if you want to install zx10 08-11 calipers with 320mm discs as i do,you have to put 2mm spacer as mine+10mm spacer(the difference between of our forks)=12mm spacer finally.
    To be sure,put some common 1 or 2mm spacers in the caliper bolt until the calipers sit fine on the rotor.Then measure the total length of these spacers and order the final one.
  11. #460
    May 2008
    Manchester NY
    705
    yeah he really knows his stuff.
    New York USA
    R.I.P.
03 636 engine swap
08 r1 custom
2006 zx6r rear stalk signal location
brake tech rotors on motorcycle gold wheels
custom zx14r
ducati monster 1100 evo homemade tail tidy
what spacers to use with 06 636 hohry big rotor kit
yamaha r1 2010 black and gold
yamaha r1 streetfighter
z1000 black and gold
z750 puig belly pan install
zx 6 front end 636
zx 636 won;t fit zx6 triple tree
zx14r
zx6r rim fit r1
