Removal of Catalytic Converter
This is a discussion on Removal of Catalytic Converter within the Z1K/Z750 Performance Upgrades forums, part of the Kawasaki Z1000, Ninja 1000, Z800, Z750 & Z-750S category; Guys, has anybody dared to remove the Cat from the stock exhaust? If yes, how? Cutting the muffler open underneath the cover? I want to ...
Results 1 to 5 of 5
    Newbie Skylark's Avatar
    Mar 2005
    16
    Guys,
    has anybody dared to remove the Cat from the stock exhaust? If yes, how? Cutting the muffler open underneath the cover? I want to avoid that and therefore I am thinking of using an airhammer thru the body of the muffler (internals obviously removed). But for that the material of the cat must be brittle. So has anybody experience with the material? Is it brittle like ceramic, or more like aluminum?
    Any advice is appreciated.
    Thanks
    Skylark
    Rising Star Crazi's Avatar
    Jul 2005
    Woodbridge VA
    40
    415
    It is not brittle AT ALL!! I used a method similar to yours and it took me a good while to get them out. They are made of what appeared to be thin stainless coated with the stuff cats are made of. I used a sledgehammer and a long rod and beat until it all came out of the other end.
    Don't know how you are going to get an airhammer in there but good luck and be careful... I bought another set just to be sure that if I screwed up, I still had something to ride.
    2004 ZX10R
    SR-71 - Stolen
    2005 Z1000 - Traded
    ALWAYS ride YOUR ride...
    Supreme Being GOODRODE's Avatar
    Aug 2003
    Kill'n what few curves we have in Kentucky.
    2,208
    You can also use a drill and a wood/blade drill bit. Use something like 1" or bigger, it does come out.
    2003 Z1000 Sold 10/01/2012
    2005 ZX-10R
    Akrapovic Ti Evo 2 exhaust Carbon Fiber LOR can, PC3 with custom map, BMC Race Filter, TRE, Moose Handlebar, Targa Seat Cowl, Race Intake Cam, Degreed Cams 107/104
    2009 ZX-10r
    2Bros Slipon, Bazzaz ZFI, Secondary Butterflies Removed, BMC Filter, Degreed Cams 109/105
    2011 zx10r
    Site Elder TheFleshRocket's Avatar
    Jan 2006
    Carbondale, IL
    599
    I spent a LOT of time with a Dremel and the "heavy duty" cutting wheels to get through both layers of metal that are over the converter. Would an air-hammer work? No idea. I bought one a few weeks ago but have yet to try it out so I don't know how effective it would be.
    The idea of getting a spare set of pipes is a good one. The ones that came on my bike are sitting against the wall in my garage, still virgin, and the spare set I bought is what's on the bike now. You ought to be able to pick up a set in nice shape for around $100 shipped, give or take $20 or so.
    See this thread for my pics of the converter and the mufflers in various states of disassembly.
    Attempting to modify stock exhaust and getting nowhere.
    --SOLD! '03 Z1000, orange
    mods: TFI, airbox mod, K&N, modded stock pipes, Ermax +15cm screen, Graphic Arts case sliders, Motivation frame sliders, Renntech passenger grab rail, 636 shock, secondary throttle sensor adjusted
    --'03 GSX-R1000, silver
    --'98 Vmax, silver/black
    --'90 CB-1, blue
    Up-And Comer steviejay01's Avatar
    May 2006
    Basingstoke
    40
    119
    If you get a new exhaust and connecting pipe you would also get rid or the converter no??
    Or is it located further down?
    Is this "bashing it out" method if you want to keep the stock can?
09 zx10r catalytic converter
2011 zx10r catalytic converter
2012 zx10r cat removal
2014 kawasaki ninja zx-10r catalyic converters eliminator
2014 zx10r easy catalytic converter removal
how to remove catalytic converter from 2011 zx10 r kawasaki
kawasaki zx6r 09 13 catalytic converter removal
removing catalytic converter from 2012 zx10r
would you want to remove cat from 2013 zx10r
zx10r cat removal
