wtf i can't open my gas tank anymore!
This is a discussion on wtf i can't open my gas tank anymore! within the Z1K/Z750 Maintenance forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; It's a known issue... ever hear your tank venting through the keyhole in the summer when the fuel heats up? It dries out any lubricant ...
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: wtf i can't open my gas tank anymore!
    Supreme Being Black Sheep's Avatar
    Feb 2008
    Raleigh, North Carolina, USA
    2,058
    85 times
    It's a known issue... ever hear your tank venting through the keyhole in the summer when the fuel heats up? It dries out any lubricant on the tumblers and then the condensation creates oxidation that caused them to seize up. I just put some graphite lube in the key hole a couple of times a year and work it in with the key. I haven't had an issue since the first time it locked up.
    dtyndall likes this.
    2012 Kawasaki Ninja 1000 | Black / Micron (for now) | OEM Solo Seat Cowl | Puig Smoke Windscreen | Targa Fender Eliminator | Rizoma Rear Turn Signals | Sato GP style swingarm hooks | M4 GP Style slip-ons
    _______________________________________
    North Carolina riders check out: NCSportbikes.com
  3. #17
    Up-And Comer Gregman's Avatar
    Nov 2007
    Fredericton, New Brunswick
    80
    Mine was getting hard to put the key into this summer so I just oiled it and the problem is gone. Pretty easy thing to deal with really, works real slick now.
  4. #18
    Newbie rhino's Avatar
    Jun 2012
    another trick ive picked up, only if you must! is take something strong such as like a nail or something and stick it under where the release is and then pull up and it will pop it open, it will peel paint though doing this
    Up-And Comer Nophix's Avatar
    Plover, WI
    81
    To keep it from happening, occasionally blast the lock with a graphite lock Lube. Do it to your ignition as well.
    Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
  6. #20
    Silver Member buster's Avatar
    May 2004
    pinellas park Fl.
    57
    1,678
    crc 556 in the green can will free it up even if stuck for years. just spray and wait 24 hours. works on seized rusted cylinder bores too.
    It is better to remain silent and be thought of as a fool,then to open your mouth and remove all doubt. Abraham Lincoln.
  7. #21
    Newbie chrisbogy's Avatar
    Jun 2012
    Alexandria, VA
    5
    I use a PTFE lubricant every few months see link:
    Master LockŪ - Care and Service of Master Lock Padlocks - Master LockŪ
  8. #22
    Nov 2007
    80
    Just put a squirt of oil in there and you will be fine. I used a good squirt of chainsaw bar oil and have not had any problems, just smooth, good working lock on the gas cap.
  9. #23
    Jun 2012
    Alexandria, VA
    5
    Keep in mind, if you live in a cold climate area and you ride in the winter most canned oil will freeze so be sure to check the freeze point of the oil. Although this really shouldn't be a problem for 99% of riders.
  10. #24
    Rising Star uriahk's Avatar
    Mar 2012
    northeast indiana
    243
    33 times
    oh man i know all about this story. remind me of when i was about 19 i had a 76 kz900 one morning i was getting ready to leave for work and was already running late decided i better check to see how much gas i have before i leave. put the key in and wouldnt turn i tried several times. by the end of the third try i lost my temper and punched the tank about 3 times(huge dent) right on top of tank and still didnt open. so sat there for a min. to calm down then sprayed wd40 on it and opened right up.to this day i still kick myself for that one (stupid teenagers and there tempers) lol.
    06 black and red.muzzy 2 into 1.caddman air filter,dobeck ejk 3.5,12" rise 1 1/4" drag bars, vtx shocks,lowered front fender
    mustang seat,vulcan classic backrest,fire and steel windshield,flyscreen,left side skull insert,relocated rectifier
    shinko ravens front/rear,throttle lock,ph customs tank bib w/pocket,imitation kuryaken grips w/throttle boss
  11. #25
    Newbie zedhead21's Avatar
    I ride my bikes in all weathers, I always go through all the locks first with a penetrating oil spray like WD40 to ensure they are clean, then I pack them full of underwater grease, I do exactly the same with all the block connectors in the wiring harness, which helps prevent any potential corrosion build up, most boat shops should sell underwater grease.
  12. #26
    Up-And Comer Mike810's Avatar
    Dec 2012
    South Florida
    29
    Interesting. I have a story of my own and I think something else is going on here. My buddy and I both have the identical bike ("11 N1K) 8 months old. My bike has had zero problems with the locks. My buddy on the other hand has been through two (2) sets of locks in 8 months. Bike is garage kept - very low miles - and there is nothing in the garage that would foster corrosion. When I tell you these locks are corroded, I mean they look like they have been at the bottom of the ocean for the last 12 months. NO amount of spray would help them. Just a big, white/green corroded mess! Dealer had to replace all the locks both times (under warranty). I think there might be a problem with electrolysis. Thinking maybe there is a ground wire problem or something along those lines causing the problem - dunno. Anybody have any thoughts on that theory?
  13. #27
    Rising Star Wizechatmgr's Avatar
    Albany, NY area
    33
    236
    15 times
    Easy way to test for potential electrolysis... start bike, put the negative probe from a multimeter on the negative terminal on batter, put red terminal to the lock cylinder. If you see anything other than 0V, you've got a problem... It doesn't rule it out entirely, but it should be about 98% accurate...
  14. #28
    Up-And Comer dtyndall's Avatar
    Orlando, Florida
    23
    67
    Quote Originally Posted by Black Sheep View Post
    Interesting, never heard it put like this. Makes sense though. I bought my Ninja 1000 new and had problems with the tank from the get-go. After a year of owning I bent both supplied keys. I ended up buying an aftermarket Vortex V3 gas cap last month and will never look back. Too many issues with stock Kawi gas caps; had a new Ninja 250R with the same problem. Best of luck OP.
cant open gas tank
how do you open a gas can on a kawasaki ninja
how do you remove a stuck fuel tank cap
how to open 2008 ninja 250 gas tank
how to open a locked gas tank
how to open an oxidized gas tank on a motorcycle
how to open key on tank z750
how to open your bike petrol tank if the doesn't work anymore
how to remove gas tank lid on 2008 kawasaki ninja
i cannot open gas tank fuel cap
kawasaki ninja 250r gas tank wont open
kawasaki ninja key not working to fuel tank
my lock on my gas cap wont open with my key
what gets a seized motorcycle gas tank cap off
what happened when my key is not working in a kawasaki ninja 250r
