Maintenance Suggestions while tank is off
This is a discussion on Maintenance Suggestions while tank is off within the Z1K/Z750 Maintenance forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; Just wondering what maintenance you guys recommend be done while my tank is off.
I've got to replace my head gasket as it is going ...
I've got to replace my head gasket as it is going out on my rider's left side and a slight bit of water has entered my engine - luckily I caught it in time.
I'm going to have the valves checked, but was wondering if there's anything else I should do while I have the bike taken apart like this.
Any suggestions/common problems I should look into?
Of course the dealer says go do the whole 9 yards and wants 700+ dollars for it. I can probably do most of it myself except adjusting the valves and replacing the head gasket correctly.
04-22-08 03:28 PM
Head gasket as in the one below the cylinder between it and the cases?
You can do the valves yourself - it's not that hard.
Admin @
Racing is an addiction only cured by poverty.
2005 Z750 R
Z750S with the following changes: 2006 ZX6R Limited Edition Forks 2006 ZX6R Front Rim 2007 Z1000 Triples Powerbronze Carbon Fiber Fender 2007 ZX14 Front Brake Rotors (310mm) 2006 YZF-R6 Monoblock Brake Calipers HEL Braided Lines, Black 2006 ZX6R Swing Arm 2006 ZX6R Shock Skidmarx Carbon Fiber Hugger 2006 ZX6R Rear Rim 2002 ZX9R Master Cylinder 2003 ZX9r Clutch Perch CRG Shorty Levers, Black Rizoma MC Aluminum Anodized Reservoirs front and rear Probolt Blue Gas Tank Filler Aluminum Bolt kit Probolt Blue Engine Case Aluminum Bolt kit Rear swingarm/suspension lift dog bones Arrow NiChrom conical slip-on Scottoiler Mk7 Powder Coated Case Covers
Get a K&N filter and do the cut out on the stock air box for better flow
Site Elder
Change your plugs! Might as well if you haven't in a year or so, it is way easier while things are apart.
2003 Z1000 in Metallic Black with custom ghost/flame paint,
4 into 1 Muzzy and PC3, -1 Front +1 Rear Sprockets, 636 complete front end/rear suspension, Pazzo Shorties, Speigler SS Lines, Airbox Mod, Disabled Secondaries, Custom LEDs integrated rear blinker, Corbin seat, Tuono Mirrors
WATCH ME SLAY THE DRAGON
http://www.youtube.com/watch?v=G6rAhAW5gX0
http://riderforums.com/showthread.php?t=56085
http://www.photoreflect.com/pr3/ViewAlbum.aspx?a=513277
Site Elder
Haha, all good suggestions
I don't know about the valves, reading through the guide it sounds like way more than I want to hassle with - guess I'm lazy...
I'll definately do the K&N and spark plugs though.
Do you have a resource/link for the cut on the airbox though?
Dang I should have taken pictures of the cutout I did, sorry man
Do a search here in this forum and i'm sure you'll find info in great detail
Paint the valve cover to match the orange on your bike.
05 Z1000, 00 748S, 02 RC46
If you're gonna die, die with your boots on
