Posted on '07+ accessories
This is a discussion on Posted on '07+ accessories within the Z1K/Z750 Maintenance forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; Hey guys the response on this thread has been noteworthy and I thought it should be posted here. Check this out: http://www.riderforums.com/showthread.php?t=41549 Big up to ...
Results 1 to 2 of 2
    Site Elder mr.jones's Avatar
    Dec 2007
    New Jersey
    597
    Hey guys the response on this thread has been noteworthy and I thought it should be posted here. Check this out: Gear lever selector (2007 Z1K WARNING)
    Big up to ninja167 for identifying the issue!
    Supreme Being falcn's Avatar
    Nov 2005
    Pittsburgh
    40
    1,089
    How did that end up in Accessories?
    Good post. I will check mine even though it is a 750
    Admin @
    Racing is an addiction only cured by poverty.
    2005 Z750 R
    Z750S with the following changes: 2006 ZX6R Limited Edition Forks • 2006 ZX6R Front Rim • 2007 Z1000 Triples • Powerbronze Carbon Fiber Fender • 2007 ZX14 Front Brake Rotors (310mm) • 2006 YZF-R6 Monoblock Brake Calipers • HEL Braided Lines, Black • 2006 ZX6R Swing Arm • 2006 ZX6R Shock • Skidmarx Carbon Fiber Hugger • 2006 ZX6R Rear Rim • 2002 ZX9R Master Cylinder • 2003 ZX9r Clutch Perch• CRG Shorty Levers, Black • Rizoma MC Aluminum Anodized Reservoirs front and rear • Probolt Blue Gas Tank Filler Aluminum Bolt kit • Probolt Blue Engine Case Aluminum Bolt kit • Rear swingarm/suspension lift dog bones • Arrow NiChrom conical slip-on • Scottoiler Mk7• Powder Coated Case Covers
