Gear lever selector (2007 Z1K WARNING)
This is a discussion on Gear lever selector (2007 Z1K WARNING) within the Z1K/Z750 Maintenance forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; Better change the title to reflect all Z's and not just the Z1000 from 2007+!
I just took mine off this morning and it was ...
I just took mine off this morning and it was dry and a little rusty in there!! I buffed everything off, slathered a lot of moly grease in between the seals and put 'er back together. Lever action was MUCH improved.
Admin @
Racing is an addiction only cured by poverty.
2005 Z750 R
Z750S with the following changes: 2006 ZX6R Limited Edition Forks 2006 ZX6R Front Rim 2007 Z1000 Triples Powerbronze Carbon Fiber Fender 2007 ZX14 Front Brake Rotors (310mm) 2006 YZF-R6 Monoblock Brake Calipers HEL Braided Lines, Black 2006 ZX6R Swing Arm 2006 ZX6R Shock Skidmarx Carbon Fiber Hugger 2006 ZX6R Rear Rim 2002 ZX9R Master Cylinder 2003 ZX9r Clutch Perch CRG Shorty Levers, Black Rizoma MC Aluminum Anodized Reservoirs front and rear Probolt Blue Gas Tank Filler Aluminum Bolt kit Probolt Blue Engine Case Aluminum Bolt kit Rear swingarm/suspension lift dog bones Arrow NiChrom conical slip-on Scottoiler Mk7 Powder Coated Case Covers
06-01-08 01:05 PM
I just took apart my 05 to check it out today and sure enough, nothing.
I put some grease in it, put some loc-tite on the foot peg bolt and put it back together.
I put the bolt (for the footpeg) on a bit to loose, at first - Then I had to take it back apart and tighten it again. I then went too tight and it didn't want to shift into N or 1st after riding.
So i backed it off just a hair and so far so good.
2005 Kawi Z750S - Frame Sliders, Carbon Fiber Muffler, K&N Filter, CRG LS Mirrors on the way!
Jasondt2001
Sounds like you got the seals not totally seated. You should not be able to get it too tight that it won't shift. I got that the first time put it back together, but found one of the seals was just a hair off, took it apart, realigned the seals to make sure they were fully seated and was able to crank down on the bolt with no problems in moving the shifter.
Admin @
2005 Z750 R
falcn
You know, after reading your post and thinking about it - I think you hit the nail on the head. I'm going to take it back apart today later and try to get the seal on it correctly. You sure are alot of help, thanks man!!
NP - if I hadn't done the same exact thing I wouldn't have known you might have had the same issue. Glad I could shed some light.
Admin @
2005 Z750 R
great post
now , i need to check mnie over the weekend........my selecter sounds clicky to.......thanks guys for the headsup...great post
[about the red loctite] Rather than forcing it, put a heat source (lighter, blowtorch on LOW) on it for a minute or two to heat it up. It will break down the adhesion and be a LOT easier to get off. Be careful not to hit the seals, etc.
I haven't taken mine apart, but if I were to, I'd stick the allen wrench in there and heat up the allen wrench for a couple minutes so the heat would transfer directly to the bolt. It needs to be hot to work, but not scalding/burning.
Checked my '04 yesterday and sure enough it was bone dry. After some cleaning with brake cleaner, a rough brush, and some WD, I greased everything up and put it back together. The bike definitely shifts easier now. Thanks for this heads up guys!
Subw00er
I just used a 2 foot breaker bar... one good yank and it was loose...
2012 Kawasaki Ninja 1000 | Black / Micron (for now) | OEM Solo Seat Cowl | Puig Smoke Windscreen | Targa Fender Eliminator | Rizoma Rear Turn Signals | Sato GP style swingarm hooks | M4 GP Style slip-ons
_______________________________________
North Carolina riders check out:
NCSportbikes.com
Newbie
new to this
thanks for all the posting on this issue. pulled mine apart after some sticky shifting and VOILA!!! night and day, you guys and gals are awesome!!
I always spray a little chain lube on the shifter/brake pedals, levers, throttle cable, clutch cable, and kickstand after I wash the bike. Works great for me, keeps everything smooth.
Newbie
I face the same problem 2 days back and I have a sleepless nite , the next morning I went to the shop that I bought my Z750 and seem that it happen to lots of Zed as ht stright away remove the lever and re grease it ..
will repacking with grease keep my shift lever from getting stuck in the up position while up shifting?
2007 z1000 heel guards
2007 z1000 shifting is weird
change gear lever motorcycle shaft
gear lever clamps
gear lever selector for motorcycle
gear shift mechanism 09 zx6r install
how do i adjust the gear foot lever on a 2011 kawasaki ninja 1000
kawasaki zx6r shift pedal lever
leo vince gp stile z750 diagram
powered by mybb clearance shift motocross pants
z007 z1000
z1000 notchy gear
z750 adjust gear lever
z750 adjust gear selector
zx14r notchy gearbox
