HELP!
This is a discussion on HELP! within the Z1K/Z750 Maintenance forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; Im new to this forum but I already need some help.... I just recently got a 05 Z1000 and me and a buddy were installing ...
Newbie
HELP!
Im new to this forum but I already need some help.... I just recently got a 05 Z1000 and me and a buddy were installing a undertail with built in turn signals. In the process of cutting, splicing and testing the bike lost power. I guess some where a wire touched. I found the blown fuse and replaced it but there is still zero power to the bike. WHAT IS IT!????
03-20-08 09:01 PM
jpjp1986
Sounds like u may of blown more the one fuse. By no power do u mean when u turn the key to on nothin at all happens?
Newbie
Yea nothing at all..i replaced the 10 amp turn signal fuse...where is the main fuse located? (30 amp)
Owners manual should list where it is.
Admin @
Racing is an addiction only cured by poverty.
2005 Z750 R
Z750S with the following changes: 2006 ZX6R Limited Edition Forks 2006 ZX6R Front Rim 2007 Z1000 Triples Powerbronze Carbon Fiber Fender 2007 ZX14 Front Brake Rotors (310mm) 2006 YZF-R6 Monoblock Brake Calipers HEL Braided Lines, Black 2006 ZX6R Swing Arm 2006 ZX6R Shock Skidmarx Carbon Fiber Hugger 2006 ZX6R Rear Rim 2002 ZX9R Master Cylinder 2003 ZX9r Clutch Perch CRG Shorty Levers, Black Rizoma MC Aluminum Anodized Reservoirs front and rear Probolt Blue Gas Tank Filler Aluminum Bolt kit Probolt Blue Engine Case Aluminum Bolt kit Rear swingarm/suspension lift dog bones Arrow NiChrom conical slip-on Scottoiler Mk7 Powder Coated Case Covers
Newbie
Well i found it in a service manual and thats what it was. 30amp fuse killed my baby. Well my z is alive again. Thanks guys!
