Tank Help
This is a discussion on Tank Help within the Z1K/Z750 Maintenance forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; I took off my tank to check the airfilter and didn't notice the two rubber dampers had fell out of place. I was only able ...
Results 1 to 4 of 4
Thread: Tank Help
    Up-And Comer mcdiver50's Avatar
    Mar 2007
    Jefferson City, TN
    59
    Tank Help
    I took off my tank to check the airfilter and didn't notice the two rubber dampers had fell out of place. I was only able to find one of them. I tried to replace it but I guess you must have to have both for them to fit. I plan on putting them back with some adhisive, but I only have one. Any recommendations on what to use? I thought about using the rubber foam sheet from the arts and crafts section at wal-mart and just cut to size. Anyone have an extra laying around? The vibs are bad around 5K and hope to fix it soon!
    03 Z1000 Black
    Full System Muzzy 4-2-1, PCIIIUSB, BMC air filter,
    CA intregrated tail light, Exetreme Graphics Front Turns, CRG blindsight mirror (left) and more to come (SOON!)
    98 ZX-6R Kawi Green (Project track-bike)
    D&D slip-on, Intregrated tail light, flush front turns, smoke windscreen
    "HONOR IS BETTER THAN HONORS" Abe Lincoln
    Up-And Comer cal linsenbigle's Avatar
    Jul 2007
    lame a$$ ohio,dayton xenia
    47
    123
    try a black foam flip flop..u know beach sandles..2 make it thicker use contact cement..2 stick 2 peices together..
    03 z1000
    04 cbr 600rr
    01 aprilia rs
    tattoos,sportbikes,twist da throttle!!
    Up-And Comer gindvd1's Avatar
    Jan 2007
    arkansas
    114
    If you what the right one back in there bikebandit has them for like 3.00. I just bought me two of them because when I had my wreck I lost both of them.
    Site Elder canuckerstone's Avatar
    Apr 2007
    758
    check the top of the cylinder heads! I thought I'd lost mine after putting in my PC - turned out it had fallen out and was resting on top of the cylinder heads.
    2005 Black Z1000 - nicely modded
