Z1000 Fork Oil Leak. What is involved in changing the fork seals?
This is a discussion on Z1000 Fork Oil Leak. What is involved in changing the fork seals? within the Z1K/Z750 Maintenance forums, part of the Kawasaki Z1000, Ninja 1000, Z800, Z750 & Z-750S category; So my drivers side fork tube puked up all of it's oil the other day.. I read somewhere that you can change the fork seals ...
    Rising Star BretCutler's Avatar
    May 2006
    Middletown, CT
    162
    So my drivers side fork tube puked up all of it's oil the other day.. I read somewhere that you can change the fork seals without taking the fork apart but I am not really sure how that is possible..
    Anyway, what do I need to do to change the fork seals? I am mechanically inclined but just want to know if it would be worth it to do this myself or save my time by having a shop do it. I guess if someone has done it and could tell me what is required and how long it took that would help me decide what to do.
    By the way, the seal went at 5000 miles. Ridden hard some..
    2008 Corvette Z51 3LT
    2011 Subaru WRX Premium Hatch in red
    2010 Husqvarna 510smr supermoto street legal race bike
    03 Kawasaki Z1000 - Hunt for 9's in the 1/4 starting 2011 season
    04 Specialized Bighit - Jr. T fork.
    03 Kawasaki KDX200
    Site Elder Expat's Avatar
    Feb 2007
    Mass
    53
    985
    I can't change seals without taking the fork apart. I have not rebuilt the Z forks but upsidedownies need to be stripped, convemtional forks can be done with a bit of butchery.
    I bet you will need some special tools to get them apart. Probably easiest to strip them off the bike and take them to a Kawasaki dealer, this will reduce a lot of expensive labor.
    Good luck.
    Expat.
    Black 03 Z1000.
    Shortened CF Akrapovic slip ons. K&N filter + air box mod. Powercommander III.
    Speedohealer. Twin light conversion. Renthal ultra lows. Bar end mirrors. Tail tidy. Sargent seat.
    Renntec grab rail (only fitted when passengers are on!) Shock racing LED mini turn signals.
    Throttle quickener. Motovation frame and fork sliders.
    Rizoma case sliders. Shorty Pazzo levers. Hyperpro RSC damper. Driven +3 520 chain conversion
    06 ZX10R wheels with stock wavy rotors.
    Custom stainless steel wheel spacers, footpeg pins, bar dampers and caliper spacers.
    06 ZX10R front and rear brakes.
    Black HEL lines with Red fittings.
    07 Silver ZX6R forks with Race Tech .95 springs.
    06 ZX6R shock. 06 ZX6R front fender.
    05 GSXR600 Track bike
    84 Yamaha RZ350 restoration project....
    88 YSR50
    00 KTM 200 EXC.
    07 Kawasaki KX100
    Site Elder fast_stakes's Avatar
    Apr 2006
    Central Iowa
    735
    You can do it without removing the cartridge, but you still have to split the male and female tubes to pull the seal out. Tools you will need a spring compressor, seal driver, wrenches, oil level guage, screwdriver (flat head), and a heat gun will make things easier but not necessary.
    Sometimes it takes a whole tankful of fuel before you can think straight.
    “Insisting on perfect safety is for people who don’t have the balls to live in the real world.”
    – Mary Shafer, NASA Ames Dryden
2003 kawasaki z1000 fork oil level
2003 z1000 front fork seal replacement
2004 kawasaki concours fork oil
2004 z1000 fork oil level
concours fork oil level
kawasaki concourse fork oil level
oil leaking from front forks z800
z1000 fork oil
z1000 fork seal replacement
z1000 fork seals
