Z1000 Maintenance Reference Pages
This is a discussion on Z1000 Maintenance Reference Pages within the Z1K/Z750 Maintenance forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; I am starting this thread to list webpages that are excellent reference sources for the Z1000. I will add more as they are found. If ...
Results 1 to 2 of 2
    Super Moderators groovyone's Avatar
    Aug 2003
    Dickinson, TX
    6,446
    I am starting this thread to list webpages that are excellent reference sources for the Z1000. I will add more as they are found. If anyone has one they'd like to add, send me or any other Admin a PM with the link and a description.
    NO COPYRIGHTED MATERIALS - this includes the Kawasaki Manuals
    REMEMBER, these links are opinion, sometimes backed by testing. Use at your own risk.
    Oil Filter Reference Guide - ALL BIKES
    - thanks to Lodogg2221
    Motorcycle Oil Reference Guide (added 6/12/08)
    - thanks to holyroller
    Oil Filter Comparison
    - thanks to dan95814
    Motor Oil Discussion - Myths of Motorcycle Oils
    Found this one very interesting.
    Motor oil bible
    Motorcycle Motor Oil Discussion
    Synthetic Oil Myths (by Mobil) (added 6/11/08)
    Synthetic Oil Myths (by Castrol) (added 6/11/08)
    Your road determines your destination
    - Unknown
    If you don't know where you are going, any road will get you there.
    - Lewis Carroll
    Aug 2003
    Dickinson, TX
    6,446
    Here are several tire links, most from major manufacturers.
    Maxxis Tire School
    Dunlop Tires
    Dunlop Touring Tire Tips
    Michelin Tips
    Metzeler Tips
    excerpt from Metzeler:
    Where are your air pressure listings, and can I run different pressures then you suggest?
    We list the minimum air pressures for most bikes sold in the North Amercian on the web site in the brochure download area. We also have a chart in the brochure that gives suggestions for running corrected air pressures for when you add a load and or a passenger. A simple rule of thumb is to always run the pressures on your street motorcycle tires towards the maximum listed on the sidewall. By doing this you will increase the life of the tire over it's useful life.
    More Tire Tips
    Scroll down and check out the handy chart.
    Avon Tire Tips
    excerpt from Avon:
    Correct-pressures– Your tyre is designed to perform perfectly at a very specific pressure. Inflated correctly it provides the optimum contact patch for superb roadholding and water dispersal, as well as giving good handling, comfort and lifespan characteristics.
    As for track riding:
    Sport Rider Tips
    For TRACK use, not street. For those of you running lower pressures, I would take a careful, close look and make sure you are not running them so low that the tire shape is not maintained.
    Canyon Chasers
    What about tire pressure and size? This one does not depend. For almost all cases go with the manufacturer's recommendations. Believe it or not, those designers and engineers in Japan, Italy, and Germany know a lot more about motorcycle design than we think we do. Your best and safest bet for motorcycle performance and handling is to run the recommended pressure. You can deviate slightly depending on what you want from your tire, but the closer you stay to manufacturer's guidelines, the happier you will be. Dropping pressure provides more traction but can compromise stability and increases wear. Increasing pressure decreases traction and can compromise stability but decreases wear. Also, check your tire pressure frequently.
    - Unknown
    - Lewis Carroll
03 z1000 best oil
03 z1000 maintenance
03 z1000 oil
2003 kawasaki z1000 oil
2003 z1000 maintence scheduel
2003 z1000 oil
2008 z1000 what kin of oil
kawasaki z 1000 engine oil
kawasaki z 1000 maintenance schedule
kawasaki z1000 tyre pressures
kawasaki z750 engine oil
oil for 2003 z1000
recommended oil for z1000
servicing for kawasaki z 1000 2011
z1000 engine oil system
