2008 Kawasaki Z1000 Fork Swap
This is a discussion on 2008 Kawasaki Z1000 Fork Swap within the Z1000 '07-'09 Accessories forums, part of the Kawasaki Z1000, Ninja 1000, Z800, Z750 & Z-750S category; UNADJUSTEDNONRAW_thumb_1af9.jpg What is the simplest method and which forks to use for fitting stock parts ? I hear the 05-08 636 Forks are the way ...
Results 1 to 1 of 1
    Newbie thorshammer77's Avatar
    Nov 2016
    UNADJUSTEDNONRAW_thumb_1af9.jpgWhat is the simplest method and which forks to use for fitting stock parts ? I hear the 05-08 636 Forks are the way to go but need bit more info if anyone can share with me ...
