#1 |
Newbie
Renthal bars
I'd like to lower the bars on my Z1000...I'm used to sports bikes and the Z is hurting my back a little at times.
Are renthal ultra lows good on the Z1000? ANybody fitted them successfully? How much lower do they make the grips? When fitting, do they go straight on with ease or do I need clamp adaptors? Also, when fitting, do I need to lengthen the cables or is it all pretty straightforward? Thanks very much. |
#2 |
Up-And Comer
from what i've heard about the ultra lows they are a good improvement, and a pretty straight forward install with no parts needed. I'm still waiting on mine to be delivered so I can get them on though.
__________________
2009 Vista Blue Focus Coupe AKA "Blue Reign" 2003 Z1000 Cafe Project 1975 KZ400 |
#3 |
Site Elder
I don't have Ultra-Lows but I have the Streetfighters, which are similar.
People who have the Ultra-Lows rave about how awesome they are. People seem to love them as I love my bend. Tons of people fit them successfully. They're substantially lower. Consider these specs: Stock height - 120mm (give or take 5mm) Ultra-Low height - 75mm Rise is also considerably less. 89mm to 50mm They're direct replacement. Since they're 22mm diamiter bars you can use the stock clamps and cables. The only thing you have to do is drill control placement holes for the controls to stay in place.
__________________
Pacific Northwest Riders.comZR1000B7F www.pnwriders.com Washington Sportbikes.com http://www.washingtonsportbikes.com/forums/index.php |
#4 |
Supreme Being
I put Renthal Ultra Lows on mine, pretty easy swap. You do have to drill some locating holes for the switch controls though. And also you won't be able to re-use your bar end weights. They're a good couple inches lower though and give a sportier feel to the bike, I like 'em.
__________________
#5 | |
Rising Star
Quote:
#6 |
Supreme Being
Or just mock up your controls on the bars first, find where you want them, mark the inside with some blue dye or a magic marker and place them back on the bars. Voila, you have a mark where you need to drill!
__________________
| Thread Tools | |
| Display Modes | |
