RiderForums.com Community
Go Back   RiderForums.com Community > Kawasaki Z1000, Z750 & Z-750S > General Z1000/Z750
Reply
Thread Tools Display Modes
Old 03-10-09, 06:12 PM   #1
Jason 306
Supreme Being
Jason 306's Avatar
Had a small problem today
Got the Z out today for the first time in a few months. Man I've missed this thing! The RC51 will go down the road long before I ever get rid of my Z!
Anyway, I went to fill the tank up and I couldn't get the gas cap open!
I pushed down on the cap while twisting the key, twisted the key until it felt like it was gonna break, tried just about everything. The thing would just not unlock, it was almost like it was the wrong key the way it acted.
Well fortunately I was able to make it back home where I unscrewed the allen head bolts around the cap. I knew this still wouldn't allow me to pull it off, but it would let me shimmy it around a little bit just in case it was just seized up somehow underneathe. Turns out, it was. Last time I filled up was probably 3 or 4 months ago (maybe longer), and I suppose going that span of time without being opened everything got stiff and seized. So after moving the cap all around and twisting the key at the same time, the thing finally opened.
I made sure I sprayed some Rem Oil down in the keyhole but I don't think that was the problem. I think the tabs on the cap that lock into the gas tank just somehow got fused with the tank a little bit, making it stubborn to unlock. I thought about spraying a little bit of Rem Oil on them, but didn't want any dripping inside my tank.
So I guess I'll just have to make sure I open the tank up maybe once a month or so during the winter...I think you should too!
__________________
Jason 306 is offline   Reply With Quote
Old 03-10-09, 06:35 PM   #2
motorbum
Rising Star
motorbum's Avatar
that happened to me too a few weeks back. now i very gingerly turn the key and push down on the cap. i think there is a thread on here somewhere, seems common. guys were talking about graphite lube or something.
Dri Slide Graphite Lubricant is the name.
motorbum is offline   Reply With Quote
Old 03-10-09, 07:04 PM   #3
masalma
Rising Star
used to happen a lot to me but a squirt of WD40 everyonce in a while does the trick.
masalma is offline   Reply With Quote
Old 03-10-09, 08:15 PM   #4
Shabbernigdo
Rising Star
Quote:
yeah i do the same thing and have never had a problem.
just stick the little wd40 tube in the key hole and spray for a second or so then open up the cap and look at the 2 little metal retracting catches and make sure they have wd40 on them too and it should all work good.
also when you fill up with gas dont over fill it till the gas is in the tank neck. the gas seems to disolve away the wd40 leaving the lock parts / internals un protected.
__________________
I'm looking at an overhaul, and adding some spray, because if your going to die on a bike you may as well be going faster than everyone else
Shabbernigdo is offline   Reply With Quote
Old 03-10-09, 09:50 PM   #5
whitebread
Rising Star
whitebread's Avatar
I'm soooo glad I live in Texas and the Z gets filled every week!!
I'm with malsama on the WD40 tip. That stuff is amasing..
__________________
'03 Z1K- 636/ZX9/ZX10/R1/ junk, no bling, some other crap, in progress..
whitebread is offline   Reply With Quote
Old 03-10-09, 10:27 PM   #6
SFTripod
Rising Star
SFTripod's Avatar
Whitebread....
.....luv that helmet on your avatar.
__________________
Floats like a butterfly, & stings like a Z!
SFTripod is offline   Reply With Quote
Old 03-10-09, 11:10 PM   #7
ballsdeepracing
Rising Star
ballsdeepracing's Avatar
This used to happen to me all the time, so I took it to the dealer and they couldn't figure it out either so I ordered a new gas cap. after almost a month of problems, and carrying around an allen key just in case I got the new cap, and wouldn't you know it my old one started working again and I haven't had a problem since. great waste of $70
ballsdeepracing is offline   Reply With Quote
Old 03-11-09, 01:49 AM   #8
jsmith8008
Site Elder
jsmith8008's Avatar
Yeah I fill up frequently enough to keep it unstuck, but I'm sure WD40 could always help. I spray WD40 on my wounds. Its very versitle.
__________________
ZR1000B7F
Pacific Northwest Riders.com
www.pnwriders.com
Washington Sportbikes.com
http://www.washingtonsportbikes.com/forums/index.php
jsmith8008 is offline   Reply With Quote
Old 03-11-09, 09:27 AM   #9
ballsdeepracing
Rising Star
any problems with getting WD-40 in with the gas?
Old 03-11-09, 09:49 AM   #10
Black Sheep
Site Elder
Black Sheep's Avatar
WD40 is good stuff, but I wouldn't use it in the keyhole... over time it will attract dirt and gunk up... graphite lube is better for locks.
__________________
2007 Kawasaki Z1000 - Diablo Black Metallic | Clear Alternatives Integrated Taillight - Smoke | Decals, Badging, and Reflectors Removed | Blacked Out Side Panels | Motrax Bar End Mirrors | OEM Solo Seat Cowl | Puig Rear Hugger | Motivation Frame Sliders | Rizoma Case Sliders | K&N Air Filter | PCIII | R6 Exhaust Mod (inverted)
_______________________________________
North Carolina riders check out: NCSportbikes.com - By the Rider | For the Rider
Black Sheep is offline   Reply With Quote
Old 03-11-09, 09:57 AM   #11
Rhinotheking
Supreme Being
Rhinotheking's Avatar
Quote:
+1...keep wd40 away from keyholes you guys!
Rhinotheking is offline   Reply With Quote
Old 03-11-09, 10:54 AM   #12
JAMBO
Newbie
Hey Peter man! Watch out fur yer keyhole buddy.
JAMBO is offline   Reply With Quote
Old 03-11-09, 10:58 AM   #13
Crystal Z1K
Supreme Being
Crystal Z1K's Avatar
Well this is the first winter I have had the Z and let it sit. I'm going to go home tonight and make sure my fuel door opens, before I need gas and can't get it in.
__________________
08 white Z1000.
Scorpion CF ovel slip on's
Targa fender Elim with LP Stinger LED turn signals.
CRG 3" Hindsight mirrors.
Reflectors removed.
Custom black Front seat with orange K.
Rear seat strap removed.
2007 HD Sportster 1200 50th Ann # 674 of 2000. Too many mods to list.
2005 Honda CRF50F-Mini Stunter.
Crystal Z1K is offline   Reply With Quote
Old 03-11-09, 11:21 AM   #14
Black Sheep
Site Elder
Did I say something funny...
__________________
Old 03-11-09, 11:26 PM   #15
jabeez
Up-And Comer
not exactly, but JAMBO did, heh heh, good stuff man, could you at least pretend we can't hear each other through the walls?!?!?
jabeez is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
2009 RiderForums.com
