#1 |
Rising Star
Need exhaust ideas!
Ok guys heres the thing, I've these 2 tastey cans just going to waste in my shed but I think they might just be the thing to trick up my Zed.
![]() Only problem is where to locate them? I was thinking underseat like the Ixil ones, or maybe even stacked on top of each other on the left side of the bike? All suggestions welcome and if anybody has any photoshop skills then please feel free to do your stuff. ![]() ![]()
__________________
![]() OEM Seat cowl Ermax Undertail Ermax Hugger CRG Shortie Levers Motrax mirrors Green Braided Brake lines Renthal brace Powerbronze Crash pots Harris grips |
#2 |
Supreme Being
Maybe just use one and mount under belly. Just an idea.
#3 |
Supreme Being
Most guys that I've seen do that usually end up with some clearance issues, but it does look good. Sometime ago a guy over in Europe mounted a stock gsxr600 exhaust underneathe his Z, best I've ever seen, but he had to do ALOT of chop-cut-rebuild to get it to work.
http://www.riderforums.com/showthrea...t=gsxr+exhaust If you want to do something different the double-barrel shotgun idea sounds neat, as long as the cans aren't too big, then it would look awkward. Good luck and for god's sake post pics!!!! ![]()
__________________
#4 |
Up-And Comer
i have always liked the look of the dbl. shot gun berrel.
#5 |
Rising Star
You might be able to get away with both of them coming off the same side, depending on how heavy they are. you wouldn't want to create any balance issues! personally I prefer the under tail look, if I ever redo mine thats where they are going. Twin Two Bro's carbon fiber triangle pipes right under the tail!!!
#6 |
Up-And Comer
Youuuuuu, could also bring all the primaries out the one side ( right side of the bike ). Bring the two right cylinders pipe up high on the right side like the Ixil's, up high under the tail section , and the left cylinder's pipe would cross over to the left side of the bike through just between the the rear tire and the rear shock and exit the left side down low.
But to make it work you would have to have the up high can stick out past the end of the tail section abit, and the left side, exit half way up the height of the bike, but not as long as the right side. Remember, you have to keep the secondaries all the same lenght. I have seen a 1984 1000 Intercepter done this way, mind you it was a V engine, but it did look sweet. This is alot of work though taking this road, but the end result would make it worth it, also depending on if you have the equipment to carry this out. Just thinking outside the box. Z ![]()
__________________
The road of excess leads to the path of wisdom, Amen. Last edited by mrZee : 03-02-09 at 05:51 PM. |
#7 |
Rising Star
The cans are 21 inches from tip to tip and 4 wide at the moment but I will be cutting them to suit and the weight is not really an issue as they are carbon fiber and have no DB killer in them.
A buddy of mune suggested 1 underseat with the other coming up the side like the GP bikes from a couple of years ago. Might work no?
__________________
#8 |
Supreme Being
Cut them down... and mount them both underbelly. Dual underbelly would be the shizzle. I'll do a photochop later today of it.
__________________
#9 |
Supreme Being
I really like this idea the best. I hate undertail exhaust so I'm not going to recomend that.
__________________
08 white Z1000. Scorpion CF ovel slip on's Targa fender Elim with LP Stinger LED turn signals. CRG 3" Hindsight mirrors. Reflectors removed. Custom black Front seat with orange K. Rear seat strap removed. ![]() 2007 HD Sportster 1200 50th Ann # 674 of 2000. Too many mods to list. ![]() 2005 Honda CRF50F-Mini Stunter. |
#10 |
Rising Star
double barrel on one side a la ducati streetfighter:
#11 |
Site Elder
Yeah do the double side thang. I've yet to see that on a Z pretty sure.
Too bad the underslung doesn't work. That Buell style would look cool ![]()
__________________
Pacific Northwest Riders.comZR1000B7F www.pnwriders.com Washington Sportbikes.com http://www.washingtonsportbikes.com/forums/index.php |
#12 |
Rising Star
just put up a poll, see where it leads you?
count me in for the double barrell on the right side a la ducati streetfighter! either ways, good luck and have fun! |
#13 |
Supreme Being
I've seen two Z1000's with double barreled exhausts on the right side - I personally don't like that look. I forgot to do a chop of that picture for you... I'll try to work on that this weekend. Also, dual under belly is possible with a Z - atleast the 2003-2006 model anyway.
__________________
| Thread Tools | |
| Display Modes | |
