RiderForums.com Community
Go Back   RiderForums.com Community > Kawasaki Z1000, Z750 & Z-750S > Z1K/Z750 Performance Upgrades
Reply
Thread Tools Display Modes
Old 05-04-08, 09:26 PM   #1
Expat
Site Elder
Expat's Avatar
Post ZX10 wheel swap details.
Here is the details for the wheel swap for the Gen 1 Z1000 to ZX10R
I used wheels from a 2006 model.
General information.
The Z1000 uses a 25mm dia axle.
The ZX10R uses a 20mm dia axle.
The ZX10R rear hub is narrower than the Z1000. therefore, the ZX10R axle is too short.
There are 2 ways to make the wheels work:
1. Fit larger I.D. bearings into the ZX10R wheel to accomodate the Z1000 axle etc. I did not go this route and my only concern would be the load and speed of a smaller diameter ball bearing as each actual ball is going to be aprox 2.5mm smaller in diameter. The spacers need to be adjusted to make the hub offset correct.
2. Use a smaller diameter axle and associated spacers and caliper hanger etc. This is the route I took and the one I am describing here.
For the front, you can use a ZX10, ZX6 or Z750 wheel, I made custom spacers so they matched the rear but if you do the 636 fork conversion, stock spacers from the 636 work. The axle etc fits also so it is a straight forward bolt in.
The rear is more tricky, because the hub is narrower, the offset is different and custom spacers are required to keep the chain alignment correct. The dimensions are shown in the drawings below. In addition to the wheel spacers, you will need 2 additional sets of spacers as follows.
2 swinging arm spacers which will take up the difference in the diameters from the 20mm axle to the 25.5mm slot in the stock Z swinging arm. I made mine 20.25mm I.D x 25.00mm O/D x 15mm (the thickness of the swinging arm slot), I cannot remember for sure but think it is 15mm. I had to grind mine slightly on the O/D to fit exactly. The other set is for the offset of the rear caliper. These can be custom made or you can use nuts which allow clearance over the caliper bolt. I made mine 18mm O/D x 8.5mm I/D x 15mm long and they work fine but I suggest you double check your own dimension here!
I used a Z750 axle which had to be shortened by about 10mm and the split pin holes re-drilled. I had mine re-plated but I guess some Silver paint will do! I then used 2 of the L.H side axle blocks from the ZX10R (one on each side) these are the thicker ones without the cut out for the axle head, I did this because the Z750 axle does not have the flats to stop it spinning when being tightened. If you use an axle with flats, it will need to shortened more but this means you will need to extend the thread which involves a special die nut, I am not sure of the actual thread size.
I have also attached dimensions for the footpeg pins which I replaced in Stainless for asthetic appearances.
I will post photos of the actual spacers in the next day or two.
If anyone has any specific questions, I will be pleased to try and help.
If you print off the following drawings and ask a local machine shop, they should be able to make them for you, like anything these days, the material is probably less than $20 but it will take someone probably 2 to 3 hours to actually make them all.
File Type: pdf ZX rear sprocket side wheel spacers rev 1.pdf (25.9 KB, 135 views)
File Type: pdf ZX rear rotor side wheel spacers rev 1.pdf (26.1 KB, 100 views)
__________________
Expat.
Black 03 Z1000.
Shortened CF Akrapovic slip ons. K&N filter + air box mod. Powercommander III.
Speedohealer. Twin light conversion. Renthal ultra lows. Bar end mirrors. Tail tidy. Sargent seat.
Renntec grab rail (only fitted when passengers are on!) Shock racing LED mini turn signals.
Throttle quickener. Motovation frame and fork sliders.
Rizoma case sliders. Shorty Pazzo levers. Hyperpro RSC damper. Driven +3 520 chain conversion
06 ZX10R wheels with stock wavy rotors.
Custom stainless steel wheel spacers, footpeg pins, bar dampers and caliper spacers.
06 ZX10R front and rear brakes.
Black HEL lines with Red fittings.
07 Silver ZX6R forks with Race Tech .95 springs.
06 ZX6R shock. 06 ZX6R front fender.
05 GSXR600 Track bike
94 Yamaha RZ350 restoration project....
00 KTM 200 EXC.
07 Kawasaki KLX100
03 Honda CRF230
Expat is offline   Reply With Quote
Old 05-04-08, 09:50 PM   #2
Jason 306
Supreme Being
Jason 306's Avatar
Good write up, I like it when people do this stuff. This may get a sticky. I like the ZX10 wheels, but they look like they would be much harder to clean than my stock Z wheels . But I like the stockers looks just as much as the zixxers
__________________
Jason 306 is offline   Reply With Quote
Old 05-04-08, 10:07 PM   #3
Expat
Site Elder
Expat's Avatar
Quote:
I clearcoated mine about 6 times and left the lips polished, if they were a brighter color they would be more difficult to clean for sure, I usually use a biodegradable degreaser in a spray bottle, hose it off and then use furniture polish to shine them up. The polish leaves a slight film on the surface making future cleaning slightly easier! I think the appearance is worth the extra cleaning!!
__________________
Expat.
Black 03 Z1000.
00 KTM 200 EXC.
07 Kawasaki KLX100
03 Honda CRF230
Old 05-04-08, 10:29 PM   #4
Jason 306
Supreme Being
Jason 306's Avatar
Yeah, they look great! It almost makes the bike look like a European Z750 in a way (they have similiar rims don't they?).
Question: Do all the 07 ZX6's have silver forks? Do they differ from 05/06 636 forks? I really like the silver better than the gold, and the black at the bottom with black calipers looks killer!
__________________
Old 05-04-08, 10:36 PM   #5
Expat
Site Elder
Expat's Avatar
You need the limited edition one, the bike was Silver with Red flames. They also did Gold and I think that was the most common color. I am not sure what colors are available in 08.
__________________
Expat.
Black 03 Z1000.
00 KTM 200 EXC.
07 Kawasaki KLX100
03 Honda CRF230
Old 05-05-08, 01:32 AM   #6
blufke
Rising Star
Thanks a bunch for putting this up.
__________________
03 Zed - Dutch Pride Edition - 128whp
blufke is offline   Reply With Quote
Old 05-05-08, 12:20 PM   #7
extensive
Rising Star
extensive's Avatar
thanks for the info. how did you make the spacers? are you going to make them for sale?
__________________
Moto Blog
extensive is offline   Reply With Quote
Old 05-05-08, 12:29 PM   #8
Expat
Site Elder
Expat's Avatar
Quote:
The spacers were turned on a lathe. I do have a couple of spare sets of the actual wheel spacers but not the ones to shim the stock swinging arm or to offset the caliper. They are made in top grade stainless, the stuff they use on oil rigs etc!
__________________
Expat.
Black 03 Z1000.
00 KTM 200 EXC.
07 Kawasaki KLX100
03 Honda CRF230
Old 05-05-08, 02:04 PM   #9
mezzo
Up-And Comer
I need some advice
I have a2003 z1000 and i ve just got hold of a 2005 zx636 front end.
Ineed to know weather i can use my z1000 front wheel if so what axel and spacers do i use, do i use the zx636 axel and spacers to marry up with the forks? or do i need the zx636 front wheel + i want to use the zx636 calipers as well
and the big question will the 2005 front end fit my 2003 z1000
Mezzo
mezzo is offline   Reply With Quote
Old 05-05-08, 03:11 PM   #10
Expat
Site Elder
Expat's Avatar
Quote:
Originally Posted by mezzo View Post
I need some advice
Mezzo
The front end will fit.
Regarding using the Z1000 wheel, see the thread for the 636 swap, it tells you which wheel spacers you need to use to make it fit.
good luck!!
__________________
Expat.
Black 03 Z1000.
00 KTM 200 EXC.
07 Kawasaki KLX100
03 Honda CRF230
Old 05-05-08, 03:18 PM   #11
groovyone
Moderator
groovyone's Avatar
Making this one a sticky. Great writeup.
__________________
Your road determines your destination
- Unknown
If you don't know where you are going, any road will get you there.
- Lewis Carroll
2008, 2007, 2006, and now 2005 CW International Motorcycle Show - Houston
groovyone is offline   Reply With Quote
Old 05-05-08, 03:22 PM   #12
Expat
Site Elder
Expat's Avatar
Quote:
Why thank you. I will buy you a pint next time I am in Houston!!
__________________
Expat.
Black 03 Z1000.
00 KTM 200 EXC.
07 Kawasaki KLX100
03 Honda CRF230
Old 05-05-08, 03:31 PM   #13
mezzo
Up-And Comer
Thanks for your advice. im getting the front end this week,so im confident now
Many Thanks
Mezzo
Old 05-06-08, 10:24 AM   #14
Expat
Site Elder
Expat's Avatar
Below is a photo showing the rotor side spacer and also the ones I used to offset the caliper. You cannot see the one used to shim the swinging arm down from 25mm to 20mm as it is located in the slot.
__________________
Expat.
Black 03 Z1000.
00 KTM 200 EXC.
07 Kawasaki KLX100
03 Honda CRF230
Old 05-07-08, 09:07 AM   #15
RS117
Supreme Being
RS117's Avatar
Great write up!!
__________________
03 Z1000 in perfect Orange W/ CUSTOM GHOST FLAMES -n-SWEET CUSTOM DENT
Hel SS lines in perfect orange
CRG LS mirrors / Renthal Ultra Lows / Shogun frame sliders / HD case sliders
Black Pazzo Shorty Levers / LP turn signals / PC'ed pieces & parts / DIY fender elim.
Black face plate cover (Thanks Goodrode)
custom dogbones / throttle quickener / BMC air filter
02 ZX9R master cylinder
06 ZX636 limited rear shock / 06 ZX636 forks w/ RaceTech 1.0 springs / 06 ZX 636 calipers
2006 ZX10 clutch perch / 2007 ZX10 wheels
/ Clear Alternatives rear integrated / hyper Pro steering dampener
Gilles rear sets with passenger pegs
PC111 w/ full MUZZY = 127.3 HP w/ 66.9 torque
just added Speedo healer / 520 +4 chain conversion w/ Stealth rear sprocket
RS117 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
2009 RiderForums.com
